Blue Clock Spring Steel - source
Discussion in 'Metals' started by GWRdriver, Sep 18, 2010.
Help Support HMEM by donating using the link above.
  1. Sep 18, 2010 #1
    GWRdriver
    GWRdriver
    GWRdriver
    Senior Member
    Jan 22, 2009
    715
    85
    Does anyone know of a source, or have suggestions for, a quantity source of blue clock spring steel? I haven't been able to measure the size required yet but it will be in the neighborhood of .250" x .025". I know where to get a single clock spring made if I want one" spring but I am looking for a quantity source. I expect to have to buy as much as 500-1000ft.
  2. Sep 18, 2010 #2
    RICHARDDV
    RICHARDDV
    RICHARDDV
    Feb 17, 2009
    45
    0
    CHECK OUT THE SCRAP PILES FOR WEEDEATER ENGINE STARTER RECOILS OR LAWN MOWER STARTERS RICHARD
  3. Sep 28, 2010 #3
    ke7hr
    ke7hr
    ke7hr
    Active Member
    Sep 9, 2009
    42
    2
  4. Sep 28, 2010 #4
    jthulin
    jthulin
    jthulin
    Apr 21, 2009
    77
    1
    Never mind how much you expect to buy, how much do you want to buy?
    Jeff
  5. Sep 28, 2010 #5
    GWRdriver
    GWRdriver
    GWRdriver
    Senior Member
    Jan 22, 2009
    715
    85
    Well I don't rightly know yet Jeff. Enough for one spring certainly, the length and width of which I haven't yet confirmed, because I need to dismantle and measure the spring on an existing drill press. But I'd open to buying larger quantity because I know these springs are very hard to come by and if making one proves to be easy enough I would make more than one, perhaps dozens. Spring dismantling and measurement has been delayed for a while by pressing domestic chores.
  6. Sep 28, 2010 #6
    Lakc
    Lakc
    Lakc
    Aug 22, 2009
    985
    43
    I probably have half a dozen laying around. The Chineese have taken over the old janitor retractable keyrings and making cheap plastic ones to use as badge holders. The cord eventually breaks and I cant bear to throw out a good spring...
  7. Oct 4, 2010 #7
    Deanofid
    Deanofid
    Deanofid
    Jul 19, 2009
    2,673
    10
    Harry, I know you were looking for a large quantity. I don't know where to get that, however,
    you might find just what you need ready made in clock springs. There are about a hundred different
    coil specs in the larger clock sizes. I do some clock work, and know you can get them in a large
    variety of widths, thicknesses, and lengths. Those three variables are indicated for each spring
    size.
    If you want to have a nose around, here is one of the suppliers I use. They might have just what
    you need without having to make them.
    www.timesavers.com
    Click 'online catalog' then 'mainsprings'.
    FYI, the springs will say "loop end" or "hole end". Loop end means they have a curled loop on the ends of the spring, as would go over a small shaft. Hole end means they have a simple hole in the ends to hook over a screw or rivet head.
    Dean
  8. Oct 4, 2010 #8
    GWRdriver
    GWRdriver
    GWRdriver
    Senior Member
    Jan 22, 2009
    715
    85
    Dean,
    Thanks for that resource. I think the spring I need has one loop end and one "bent" end and if not springs then I'm sure I'll find something else useful in other areas.
    Followup - My spring is .025" x 3/8" x approx 80".
    Dean, so far as I was able to find Timesavers doesn't have any spring stock thicker than .018".
Share This Page
