1906 Lime (French origin) 7 in stroke hand shaper
holmes_ca
........Edmund...Alberta
HMEM Supporting Member
Alberta Canada
Just in case any member is interested, I have a channel on you tube, under the name Walter Maisey, I'm in the process of building a .800 scale of the full size machine, the base is 12" x 8" x 2" inches mild steel, it weighs 56 lbs and I am machining 7 off 3/8 T-Slots all on the tiny Taig Mill,
www.youtube.com/walter maisey
Hi do you have plans for this shaper ?
thanks
Hello Luc,
I have communication with the owner who gave me some rudimentary measurements on scraps of paper in metric which I first converted over to decimal, the only other knowledge is gained by photos, from that I have made a couple of rough drawings from my vision so it really is a freelance project, the drawings were produced in order to scale from full size down to a smaller .800 scale which I thought might be doable on the small Taig Machines, as I'm not entirely skilled at producing professional cad drawings they do give me some guidance that it will work out, providing my machinery can cope,
Thanks for the interest shown......Edmund......Alberta,
Hello Luc,
Hi Edmund,
Thanks for answering. If you don't mind sharing those info or picture
I would appreciate . What would the final size dimension. AS for CAD
I master that pretty good and using the pictures knowing one measurement
putting together should be pretty straight forward.
maybe this link will help you
http://www.vintageprojects.com/machine-shop/Shaper.pdf
cheers and good luck with your project
Hi Edmund,
Hi Luc,
I will try to find the dimensioned sketches I received, and any pictures related,
Luc, I am not being to successful uploading on site, contact me at
holmes_ca_2000 at yahoo.com
