- Jan 4, 2011
- 1,334
- 344
How do you set the lathe cross feed to a precise angle? Seem like after all this time I would have figured out the correct method. I have to machine a long valve seat and the mating valve to a precise 45° angle. Eyeballing it obviously is not the correct method. The problem is that for one piece the compound must be set at 45° right and the other piece must be 45° left. I have a precision triangle but holding it against the chuck face while I move the compound and work an indicator leaves me short on hands. I am not even sure that the chuck face is rally the proper surface to index from.
