Chuck,
It mostly depends on the era of the locomotive. The operating pressure kept increasing as metallurgy developed. In the civil war era, 50 to 75 PSI was typical with many of the boilers still being built with wrought iron plates. As steels developed the pressure kept increasing and by the early 20th century pressures were about 200 PSI max. At the end of the steam locomotive era, 250 PSI was a rather common upper end. As those pressures were reached, lubrication was becoming a problem with piston locomotives as the high temperature steam made the common lubricants ineffective as they were washed away by the steam.
There were a few turbine locomotives built and some hybrid turbine-piston locomotives, where the turbine ran at high pressure and the exhaust was used as part of the steam supply for the lower pressure pistons. In one system, both a high pressure and low pressure boiler were operated by the same heat source. The high pressure portion of these locomotives and the pure turbine locomotives was 1200 to 1500 PSI.
The one in the video was probably in the 225 to 250 psi range as it is a fairly modern locomotive. They are still building and using conventional piston locomotives in China as they can use low grade fuel which is easily available. Higher grades of fuel, such as Diesel, are in short supply.
Gail in NM,USA
