Some boiler questions (and hopefully my progress)
Discussion in 'Boilers' started by Brookesy, Nov 29, 2017.
Help Support HMEM by donating using the link above.
  1. Nov 29, 2017 #1
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    My brain hurts... Reading, reading, reading, sketching, drawing and so far I've managed to flesh out the basics of a design-as-you-go engine based (loosely) on 'Steve's Simple Engine/Boiler' using materials I have on hand (mostly left over from my attempts 25+ years ago) as much as possible. Hopefully the end result will be an oscillating engine of approx. 12 mm bore with a 50 mm diameter copper boiler.
    I'll put my questions here as they come to mind.
    Question #1 - Silver Solder: I have a few bits left over but they won't go far. Can any Aussies please advise a good product/silver %/source for silver solder?
    Bearing in mind future projects will increase in size etc.
    Thanks Folks
  2. Nov 29, 2017 #2
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,995
    1,112
    I have just ordered some from Wayne Roberts at $20 per stick
    ME model engineering supplies Melbourne You can download
    his extensive catalouge and price list for most things including castings
    and fittings etc.Not cheap but good service
  3. Nov 30, 2017 #3
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    Thanks for that.
    Looking around suggestions are generally 40% silver. Any comments would be great
  4. Nov 30, 2017 #4
    abby
    abby
    abby
    Apr 14, 2009
    344
    84
    Brookesy for such a small oscillator a soft soldered boiler would be quite adequate , good enough for Mamod !
    Dan.
  5. Nov 30, 2017 #5
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,995
    1,112
    I think 45% is the std but soft solder may be adequate for sealing if the
    joints are also mech. fixed. Ie rivited the soft soldered for sealing
    Soft solder is poor for a mech joint until it has a large surface area
    it tends to crack with time,movement or vibration
  6. Nov 30, 2017 #6
    fcheslop
    fcheslop
    fcheslop
    Apr 7, 2010
    619
    121
    The land of the Prince Bishops
    I realise this company is a bit to far away from you but the site has some very good information about and also using silver solder products
    For a simple pot boiler in copper I would still silver solder it even if its just to practice or hone up some skills
    Iv recently started making a small batch of Bowman Peter Pan steam boats with a nice little wobbler
    Here is the link http://www.cupalloys.co.uk/for-model-engineers/
    Good luck with the build
    kind regards
    frazer
  7. Dec 1, 2017 #7
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    Thanks for the replies folks. Yes indeedy, this project is all about using mostly what I already have in the shed and rubbing the rust off skills I haven't used for a very long time, so silver soldering is high on the list. I'll check out that site.
  8. Dec 15, 2017 #8
    texta
    texta
    texta
    Active Member
    Sep 17, 2013
    34
    19
    bunnings in toowoomba carry a good range of solder's thats where i get mine from .
    Brookesy likes this.
  9. Dec 16, 2017 #9
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    Thanks mate. I'm in Warwick so it's not that far. Bunnings here is a bit limited
    I bet it's hot in Texas today
  10. Dec 17, 2017 #10
    texta
    texta
    texta
    Active Member
    Sep 17, 2013
    34
    19
    no probs . samios plumbing in toowoomba carry a good range of copper pipe if you need any of that .
  11. Dec 17, 2017 #11
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    Thanks mate. Good to know
  12. Dec 28, 2017 #12
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    Well folks, I have another boiler related question...
    The steam engine is coming along and I'm ready to silver solder the frame so it's time to build a brazing hearth. Fire bricks are about $20 (Au) each here and CalSil is very expensive - about $30+ (Au) for a piece about 250 x 120 mm. Looking at Hebel blocks they're a lot cheaper but they're 'special order' at Bunnings, not kept in stock. The Q: Has anyone used Hebel blocks for a hearth and also does anyone know a stockist?
  13. Dec 29, 2017 #13
    deeferdog
    deeferdog
    deeferdog
    Well-Known Member Project of the Month Winner
    Mar 23, 2014
    197
    210
    Hi Brooksey,
    I made a small wedding/braizing box and lined it with Hebles from Bunnies. Never had any issues. Hope this helps. Cheers, Peter.
  14. Dec 29, 2017 #14
    Cogsy
    Cogsy
    Cogsy
    Jul 30, 2012
    2,026
    570
    Gender:
    Male
    Don't know what you have in your area but I went to an 'artsy' type little pottery shop here in Perth and got super lightweight insulation bricks for about $6 each. Same shape and size as a normal brick but almost the weight of Styrofoam. I just keep them loose and arrange them into the shape I need as I need them.
  15. Dec 29, 2017 #15
    Brookesy
    Brookesy
    Brookesy
    Oct 31, 2017
    56
    18
    Thanks fellas,
    Good to know the Hebel is ok.
    I'll be going through Brisbane tomorrow so I'll check around. The bigger Bunnings might stock it
  16. Mar 9, 2018 #16
    MRA
    MRA
    MRA
    Feb 14, 2012
    122
    27
    This is an old thread - but I thought I might mention that the ceramic (?) radiant panels out of an old gas fire make OK material for building hearths out of, and if you can find a scrap gas fire they're free!
Share This Page
