About 9 months ago, when I first decided that I wanted to play machinist, I bought my lathe. Then, I decided I could do milling in my lathe, and against the advice of more experienced and wiser heads than mine, I bought one of those cheap Chinese 2-axis slides--You know, the $35 ones. Of course, it didn't really work worth a darn and I ended up buying a milling machine. My rounding off "by eye" leaves a lot to be desired, so today when I went to round off the end of my piston rods, I resurected the Chinese 2 axis slide and mounted it on my old drill press with a sanding drum in the chuck. I had a peice of 1" square aluminum bar with a 1/8" hole reamed in the end of it, so I chucked it up in the Chinese thingy and slid the end of the 3/8" square brass bar (which I had drilled and reamed a 1/8" hole in the end of) it over the pin, then advanced the Chines vice untill I had contact between the end of the brass square bar and the sanding drum. then I swung the brass bar back and forth 90 degrees to either side. Man, did it ever do a nice job of rounding off!!! This is not an original idea--I seen it before on either this or the Home Machinist website. It just works so darn nice, I thought I would bring it up again.---Brian
