I want to put a motor on the 'Z' axis (with limit switch) of my mill\drill for ease of tool changes, setups and such. How do you figure out how many ft\lbs or what ever flavor of force (mN/m) it takes to turn the z axis shaft? To match a motor to it? Thanks
On the same note, I came across a Mitsumi stepper motor (M55SP-2k) from a printer and knowing diddly squat about dc motors would it be usefull\powerful for such an application? According to the Mfgr's web site, the motor is 24V DC, duty Amps 0.8 Peak 1.2 Amps. 7.5°\step, Holding Torque(?) 156mN/m ~ 200mN/m, Pullout Torque(?) 101~154mN/m at 800PPM, Pull In Torque(?) Max Pull Out Pulse Rate 3000~1to750PPM Max Pull In Pulse Rate 350~390PPM. It also menntions somthing about being a "4 Layer" motor? Thanks again for any insight, this stuff is Γρεεκ to me (for now)
Thanks again,
Chazz
Thanks again,
Chazz
