CNC advice please
Discussion in 'CNC Machines and Conversions' started by jgarrett, Mar 18, 2018.
Help Support HMEM by donating using the link above.
  1. Mar 18, 2018 #1
    jgarrett
    jgarrett
    jgarrett
    Aug 22, 2007
    192
    1
    Hello,
    I want to build a stepper motor to control a single axis on a small milling machine.
    I would like to be able to vary direction and speed from a "box" without having to use a PC.
    Is this doable?? Any help would be greatly appreciated.
    Julian
  2. Mar 18, 2018 #2
    blighty
    blighty
    blighty
    May 3, 2011
    372
    46
    sorry, I have no advice for you, but I have been wanting to do this my self for a while. would be useful for many applications.
    like you, I would like a small box that you can plug a stepper into and with a rotary knob speed it up slow it down. job done, nice and easy.
    would also like two switches, so when your thing hit one switch it would reverse the direction. hit the other switch then come back, so on and so forth.
    probably an easy thing to do with Arduino and some simple programing. but being simple I cant program Arduino's.
  3. Mar 18, 2018 #3
    blighty
    blighty
    blighty
    May 3, 2011
    372
    46
    found something that might get you up and running.
    did a search for "arduino stepper motor speed control potentiometer" lots came up. vid below has what you want. has the code for it @4:28. but nothing about how to wire it up. also he used a little stepper. there must be boards for bigger steppers.
    under the same search you will also find step and direct projects.
    [ame]https://www.youtube.com/watch?v=gSnGQjxpYP4[/ame]
  4. Mar 18, 2018 #4
    BaronJ
    BaronJ
    BaronJ
    Grumpy Old Git.
    Dec 6, 2013
    656
    241
    Hi Julian,
    It would be interesting to know exactly what you want the motor to drive ? Most people don't want a complicated solution to what maybe is a simple DC motor and variable voltage power supply.
  5. Mar 18, 2018 #5
    jgarrett
    jgarrett
    jgarrett
    Aug 22, 2007
    192
    1
    Baron,
    I want to use it to drive the X table on my mill (24").
    Yes you are right...I probably could use a DC motor and gears to do the same thing.. It's just that I plan to get into CNC at some point and this would get my feet wet..
    Julian
  6. Mar 19, 2018 #6
    Cogsy
    Cogsy
    Cogsy
    Moderator Moderator Global Moderator
    Jul 30, 2012
    2,108
    599
    Gender:
    Male
    You're right, it likely would be fairly easy to get an Arduino to control in the way you want, even with the auto reversing limit switches. Unfortunately it would take time, which I don't have at the moment, otherwise I'd be prepared to give it a go. I'll keep it in mind for a later date though.
  7. Mar 19, 2018 #7
    Buchanan
    Buchanan
    Buchanan
    Buchanan
    Nov 21, 2012
    167
    178
    This is what I use . It has forward and reverse as well as start and stop. Also oscillate between forward and reverse. You will also need a 48 volt power supply. The prices are for multiple pieces, 2 and 4 of each. They work really well.
  8. Mar 19, 2018 #8
    rodw
    rodw
    rodw
    Dec 3, 2012
    1,063
    315
    If you just want to drive 1 axis, you could use my Arduino controller which supports linear motion.
    http://www.homemodelenginemachinist.com/showthread.php?t=25091
    But if you wanted to get into CNC, you could consider Grbl on an Arduino which has a subset of full blown CNC Gcode control.
    For an Aussie, steppers online are hard to beat for Stepper motors. Grab a NEMA 23. They also sell power supplies too but a better option might be to grab a Meanwell 48v Power supply from Power Supplies Australia. a 7 amp supply would be enough for 3 axis into the future.
    I've had good results from Longs Motor DM542A stepper controllers from eBay that look similar to the image above. They have an elephant logo on them. There are a few other brands of dubious quality with a similar part number.
    If you poke around on eBay you should be able to find a 48v to 12 V buck power supply to Power the Arduino.
    Feel free to PM me as I'm in AU.
  9. Mar 19, 2018 #9
    blighty
    blighty
    blighty
    May 3, 2011
    372
    46
    this is exactly what i was after.
    [ame]https://www.youtube.com/watch?v=stxFDjTuzkA[/ame]
  10. Mar 19, 2018 #10
    BaronJ
    BaronJ
    BaronJ
    Grumpy Old Git.
    Dec 6, 2013
    656
    241
    Hi Julian,
    That is what I thought, See this link
    http://www.homemodelenginemachinist.com/showthread.php?t=23130
    Whilst I hear what you say about going CNC, I offer these thoughts:-
    Using a stepper motor to drive the table is not always a good idea ! The reason is simply because a stepper motor moves in discrete steps.
    Consider this, suppose your machine table moves 2 mm per turn, as mine does, most stepper motors have 200 steps per turn, that means that your table will move 0.01 mm for each step. Depending upon the tool you will have discrete cuts at these intervals, this causes a banding effect on the work surface. Not always acceptable !
    There are methods of minimising this effect, micro stepping, gearing etc. DC motors and servo motors don't suffer this problem.
    Stepper motors are great at positioning with repeatability and accuracy.
  11. Mar 19, 2018 #11
    jgarrett
    jgarrett
    jgarrett
    Aug 22, 2007
    192
    1
    Baron and others,
    After a lot of deep thinking I'm not sure that at my age I want to tackle something like that,,, I will probably just go with the DC motor option,
    Julian
  12. Mar 19, 2018 #12
    Buchanan
    Buchanan
    Buchanan
    Buchanan
    Nov 21, 2012
    167
    178
    It has the advantage that there is no extras required,like programming or PC.
    I have two that have run hundreds of hours on an industrial machine. They also switch on from "cold" instantaneously.
  13. Mar 20, 2018 #13
    Rndmann9
    Rndmann9
    Rndmann9
    May 30, 2016
    148
    26
    Check into a gshield. And an arduino. If you want a servo solution
  14. Mar 20, 2018 #14
    Herbiev
    Herbiev
    Herbiev
    Administrator Staff Member Administrator Moderator Global Moderator
    Jan 6, 2011
    2,319
    292
  15. Mar 21, 2018 #15
    Buchanan
    Buchanan
    Buchanan
    Buchanan
    Nov 21, 2012
    167
    178
    Yes , that is the motor driver. you still need a step and direction pulse generator and a 10 amp dc power supply 24/48 volts. The pulse generator can be a PC, aduino or the other board in my first post. It has a lot of very useful features in a small simple package that needs no programming.
Share This Page
