Darwins 15"Duplex oil pump from WW2 tunnels
Discussion in 'Team Builds' started by TopEndScraper, Aug 6, 2013.
  1. Aug 6, 2013 #1
    TopEndScraper
    TopEndScraper
    TopEndScraper
    Jul 23, 2013
    18
    10
    im Just wondering if any members are from Darwin or the Northern Territory , Australia
    Ive started to draw up the " Kelly & lewis , 15" duplex pump " from the Darwin WW2 oil storage tunnels , and just seing if any one is interested in making one ( or 2 )
    Im drawing them in CAD , and have a CNC machine to make the patterns , and have the furnace / sand to cast the peaces
    I was looking at making 6 of them , the set has 2 identical pumps , 1 set for the Tunnels , one set for the Qantas Hanger , and one set for me
    [​IMG]
    These are the pumps , they were made in the late 1920's in Melbourne by Kelly&Lewis ( still trading ) and the photo is of the Darwin oil storage pump shed , and how they were set up , there still there in the building , but decommissioned ,
    [​IMG]
    [​IMG]
    The only set of plans i could fine are a bit hard too read the measurements but easy enough to scale off what can be read , Ive emailed Kelly & lewis to see if they have a better set of plans showing the valve lay out inside the pump head , but i can always go see the port authority as the pumps are still in position
    [​IMG]
    [​IMG]
    the scale i was going to use , was based on the bolt size , so drawing it to take 2mm bolts so i dont have to modify the plans too much and change the way they look , wall thickness is always a problem when scaling but should be able to hide those internally , scale should end up 10:1 , so a 13/16bolt ends up 2mm
    so if anyone is interested , keep in touch
    cheers ken
    larry1 likes this.
  2. Aug 6, 2013 #2
    aarggh
    aarggh
    aarggh
    Oct 14, 2012
    296
    53
    I'd certainly be interested Ken! I'd have to rely on buying a casting set off you though mate if that's alright? As my pathetic little furnace has given up the ghost (again!). Looks like a great project.
    cheers, Ian
  3. Aug 6, 2013 #3
    Herbiev
    Herbiev
    Herbiev
    Administrator Staff Member Administrator Global Moderator
    Jan 6, 2011
    2,345
    301
    Looks like a great project. Great find
  4. Aug 6, 2013 #4
    TopEndScraper
    TopEndScraper
    TopEndScraper
    Jul 23, 2013
    18
    10
    love how quick Turbo cad16pro is , i even surprised my self , drawing this in one day ( only started CAD 18months ago)
    A lot of the edge thickness is 1.6mm , its getting a bit on the thin side , looks like "core sand " flasks , and heating the moulds , ive got a heap of tin , has any one made one out of pewter ? (tin copper mix ) and would it be hard enough , at least i can get it thin with pewter , 1.6mm with aluminium is asking for trouble , its only the flanges , ive already had to modify the scale so it looks right , most is 3mm , and i could always add extra to the flanges with Draft , and CNC off the extra after their cast for the gasket faces ?
    [​IMG]
    The clear bits sticking out are the Core's for casting , i just render them as glass , and leave them in coz ill need them for core moulds
    I just need a point in the right direction , on some reading material about the " box " that sits on top of the engine , and regulates the direction of piston movement , i dont even know what its called , and google didnt like the " doo flacky , thingimy bob , that sits on top "
    So if any one has a link handy that explains exactly whats going on in there , ill draw up the core's , the only image i have is the last page on the first "message " , and that doesn't explain any thing
    EDIT;so its called a box sliding valve , lol , who would have thought , easier than i thought to core , the hardest part would be the stting of the " throw " with lever length , looks like a bit of trial and error
    [​IMG]
    larry1 likes this.
  5. Aug 7, 2013 #5
    TopEndScraper
    TopEndScraper
    TopEndScraper
    Jul 23, 2013
    18
    10
    I set the Bell and bells core out tonight , in the Pattern for casting , their's a 3mm wall all around , i also added 1/4 to the length of the bell , it was a bit short on the original
    [​IMG]
    the STL CAD file is attached in Zipped form
    View attachment 15DuplexBell&Core2.zip
    larry1 likes this.
  6. Aug 7, 2013 #6
    TopEndScraper
    TopEndScraper
    TopEndScraper
    Jul 23, 2013
    18
    10
    And knocked out the lid as well , same 3mm thickness all through , the bottom flange will need 1/2ing / facing to match the original image , but i needed 3mm there
    [​IMG]
    View attachment 15DuplexLid.zip
    larry1 likes this.
  7. Aug 8, 2013 #7
    TopEndScraper
    TopEndScraper
    TopEndScraper
    Jul 23, 2013
    18
    10
    And i did the " Spacer " today , and its core , these patterns are set up , core sand , just ram the sand in , gas bake , and fill , i found a supplier of M1.2 mm bolts , so the scale is about 1:30 , bore size should be about 10mm , its one of those things , wall thickness becomes a huge problem, at 3mm wall the core on this part ends up 7.6mm dia ,
    [​IMG]
    STL CAD file as zipped in the attachments
    View attachment 15DuplexSpacer.zip
    larry1 likes this.
  8. Aug 10, 2013 #8
    TopEndScraper
    TopEndScraper
    TopEndScraper
    Jul 23, 2013
    18
    10
    larry1 likes this.
  9. Dec 2, 2014 #9
    rosenguyen
    rosenguyen
    rosenguyen
    Dec 2, 2014
    6
    0
    You definitely did a great project. I would love to see more in future. Congratulations
  10. Jan 7, 2015 #10
    rosenguyen
    rosenguyen
    rosenguyen
    Dec 2, 2014
    6
    0
    Looking forward to your posts soon
Share This Page
