Compressed Air Supply
CrewCab
Me again with yet another question gang ::) ......... ;)
Having managed to actually create a little engine that actually runs :eek: ..... OK no one is more surprised than me ???#
One of the problems I came up against was actually delivering compressed air to the engine . Solution seems to be to take one output from the compressor to some sort of manifold with ................. 2 or 3 outlets at a reduced diameter ........ output side I don't think is much of a problem, but the input .............. standard PCL type couplings are a tapered thread IIRC circa 13mm ............. ???
Any help appreciated.
CC
I use a short piece of 3/16" brass rod drilled through and threaded 10-32
to screw into a 10-32 tapped inlet.
3/16" fuel line that is commanly available here fit snugly onto it.
Rick
Thanks guys, got it sorted with a trip to the local tropical fish shop ;D .......... bit of plastic tubing and a couple of screw type plastic regulator valves ............ turned down a PCL fitting to fit the plastic pipe and I'm all sorted .......... for about £2.75 ($5.50)
Cheers ;)
CC
