Hi Craig,
4 feet is fine. A double simple would be my choice, say 3/8 x 3/8 x 3/8 or bigger. Easy and positive starting and reversing. A vertical firetube boiler would be best in keeping with the "real thing" and it would be easiest to build. I believe there is a plan set in the download section for a vertical firetube boiler that just might fit the bill....It would lend itself to gas firing also.....check it out!
And engine driven feed pump and a manual hand feed pump would also be on my list of musts...to say nothing of the mandatory gauge glass and safety valves mind you.
You might also consider a pressure controlled gas valve to control the fire.
All of these items exist on the open market and there are enough plans floating around that you could make all of them if you so desired....the world is your oyster.
Hey Bob, good to hear from another San Pebbles fan....shame the chief cooly didn't put the jacking gear key back when he overhauled her huh : ;D
Been busy with a new job......58 hours last week...with two hours of driving every day........cutting into my steamboat time.
