Owen_N
I have an existing muffler for a 70cc engine, which is about 65mm diameter and 300mm long.
Output when running is roughly 95 dB when I run it in the garage- blowing the exhaust out the main door.
Can I make a muffler that fits in a similar space but is quieter?
The outlet pipe is about 16mm diameter, and 2x inlet pipes of about 20mm.
There is not enough room for a tuned pipe with a muffler.
A tuned pipe for an engine like this is getting on for 3 feet long- 900mm or so?
The engine has to peak around 6000-6500 rpm.
I can go slightly longer and wider with the muffler size.
This one is all aluminium, so it will be hard to match the weight.
I don't want internal packing, but external wrapping can be used.
The engine chucks out too much oil to use packing internally.
It possibly gets a little hot for Styrofoam, but is OK with plastic wire ties.
Attached-some muffler design images.
The "simple perf" looks buildable, but may not be as effective as some of the others.
Any ideas or experience?
I will look for a cross-section of the existing muffler type, and post that, too.
The RC plane forums don't usually get down as far as muffler internals.
