DRO on mini-mill - anyone have these?
I have put them on all 3 axis and have to say...I like them a lot !! Good for the home shop without spending $500.00 to $800.00 or whatever on a glass scale set-up. I will post a couple pics after work. The batteries in mine are still running strong after about 9 months. The spare set still in package !! I don't have any issues with the units turning off or things of that nature.
V 45
Thanks so much V 45. I am really intrigued by the price of these, so I'm glad to hear they do a descent job for the money. Really looking forward to seeing pics of how you installed them so I can perhaps do the same to mine.
V 45
I have a pair on the X and Y axes on my LatheMaster LMT25L mill. I installed them a couple of months ago. I haven't had as good luck with the batteries, I'm already on my second set. Mine don't ever turn themselves off.
I'm really glad I bought them and I don't know how I ever got along without them.
Steve Fox
Here are a couple pics for you...
I made a couple of blocks to mount and used the existing tapered block for the stop. I copied that from another site...modder.
I mounted the readout on the motor cover (I cut it to cool it better)
Here is another one...
The Z was pretty straight forward...just made a z bracket from aluminum with a little spacer behind it.
Hope these help.
Thanks for the pics V 45. I plan to so something to my x2 very soon.
Also V 45, is that a 12" DRO on your Y axis? I'm asuming I would only need a 6" on my X2 since I only have about 4" of travel anyway, although it looks like maybe perhaps a 12" would be easier to mount the way you mounted yours.
The Y and X axis are both 12"..The Y was cut down a little to fit. The 6 would have been too short. You can cut these with a dremel cut-off wheel in no time !! My X axis was a 24 and cut about an inch off that one.
I just finished putting the IGAGING on my mill few days ago, month before i put them on my lathe, very happy with them and i checked them with a good quality dial indicator and they are quite accurate. It not a DRO system with all bells & whistles as offered by OEM but for costs 10 times less
Here is some pictures:
Here are a couple of pictures of my machine. I used the 6" scale for the Y axis. My total travel with the DROs installed is about 5" on the Y. I installed the X axis DRO on the back of the table because my power feed cutoff switch is on the front. I made brackets from sheet aluminum for the sensors and used the included brackets for the scales.
The first picture is the back left corner of the table and shows both the DROs. The second picture shows the power feed cutoff switch housing. Since I took these pictures, I added an aluminum swarf guard over the X axis DRO and leveled the power feed switch housing so it doesn't stick up above the table. I also added wire looms to protect the wiring.
I dont know why would someone bother using these cheapy one when you can get the real stuff for less I purchace these about one year ago. The brand is Diltron one is a 2 axes for my lathe and a 3 axis for my mill
the 3axes with all the cable mounting hardware scale cost me 350.00 us
Ive install a data switch and Im changing the input from my big lathe to my Taig lathe. I didnt do it with the mill cause my small mill is CNC and it came with itdro1.jpg
Where did you find those?
I just did a search and they don't come up. When I was looking for a set, the cheapest I could find were about $700 for a 2-axis unless I bought directly from China. I could get those for about $400 and they had mixed reviews. I couldn't even find a 2-axis display for $350!
That's why people are looking for a cheaper solution. I've seen people that spent more for the DROs than they did on their mill.
I admit that they are worth it, I just couldn't justify the cost.
You are here:
This is Shars tool page and this dro set is EXACTELY the same the only difference THE STICKER FOR THE NAME BRAND
8" x 20" x 6" 3 axis Dro digital readout glass linear Quill Milling Package
Product Pricing
Your Price:$705.00Availability:Quantity:In stock
Add to CartE-mail Me When This Item Goes In Sale
  • Click on Thumbnails to Enlarge Photos
  • Print this Page
  • Send page to a friend
That's one of the sets I found for $700.
Are you saying these go on sale for 50% off?
yes sir the controller itself No scale is 135.00 and you can purchase rotary encoder in state for 35 to 55 a pieces
if you don't want the big scale
Eagle America has the inexpensive ones on sale here:
Low cost DRO
Under $150 for 3 scales. I have had mine on my X2 mill for several years now and they still work great. One warning though. They DO NOT like swarf. I fabricated some clear plastic shields for my X and Y and had no problems.
