I might braze the bad teeth if I can't get something to make another one. I really need to get the lathe going. My Atlas isn't as hefty as th Grizzly. The gear an shaft are not available.I think bronze may be what you need.
I see folks brazing up gears and then grinding or cutting the tooth (teeth) back to shape, and it would seem that would be the easiest and quickest fix.
I have tried casting one gear, and could not get it to pull from the sand cleanly enough to be of any accuracy.
If you are going to cast a gear blank, and then recut the teeth, why not just braze the broken tooth/teeth, and cut those teeth only?
My skiis certainly aren't what they use to be, but I can do it. If I braze it I'll probably recut on the Bridgeport. My machining skills are better than my welding skills.My Dad repaired a cast iron gear with a piece brazed in and 3 new teeth filed carefully....- as good as new - to drive lathe.
Depends on your skill.
I did make the shaft yesterday.machining
Yay. Got my lathe back together. Brazed and recut the gear. All finished and running. Thanks everyone..If you are sure you are going to machine the missing teeth, you might find this useful. It's an effort to make the rack-form (not helical) hob, but it works - I have done it for Boxford change gears. I hardened mine with Kasenit in a small pot left in the woodstove for the evening.
http://www.helicron.net/workshop/gearcutting/method/
You might prefer to just buy the involute cutter you need, or even cut the teeth with a slitting saw and then sort out the flanks with a file. I seem to like putting lots of effort in to save a few quid.
