V4 howell manifold drawings
mic
hi
attached V4 howell manifold drawings, used cast iron for material as aluminium does not solder and when i used loctite it failed when running, sucked air through
mic
Here's some other choices. Make it from steel and silver solder the plugs in. Make it from brass and soft solder the plugs in. Make it from aluminum and press and solder the plugs in. Yes aluminum will solder. I have just done that to several of the aluminum parts I am making.
http://www.ebay.com/itm/like/171725875665
http://airgas.com/product/Welding-P...=da94bb7d07176cf502014b6b1c17efec&fo_s=bingus
Hi gbritnell,
Thanks for the vendor info. Will be useful if I ever come up to make the V-4.
Now still at the outerheads but making the rocker arms and clevises/clevi. Might as well do the carbs too. and from there move down to pistons etc etc.
hi
mic
Hi Mic I am building a howell V 4 any chance i could get a copy of your drawings for the manifolds i cant make out all of the dimensions in your post online Thanks Randy
