Recently purchased a used Select 816 B lathe. I have attached lots of photos. According to the spec sheet that came with it, the swing is 8 3/8", distance between centers is 16", weight is 275 lbs (don't know if that includes the legs and motor, but it felt like it did not). Hardened and ground bed ways. Also, taper roller bearings. I hope to be able to locate a manual for it or a similar lathe. Per my research, it was made in Taiwan around late 1970's or 1980.
I have not confirmed it yet; but, the spindle thread appears to be 1 1/2 -8 with, I think, may be a MT#3.
Came with a 4 jaw chuck, 3 jaw chuck (both made in England), faceplate, live center, tool holders steady rest, follow rest, tool bits,and various other items, It even came with a milling attachment that may be aftermarket that Have not yet tried to see if it fits.
Runs very nicely, back gear too. However, the spindle bearings appear to be heating up. Don't know if the heat is excessive or not. Looks like the bearings have grease zerk fittings that were surrounded with grease when I got the machine, so I added some bearing grease.
I hope to be able to find a manual for it or for a similar type lathe. Any help would be appreciated. Also, any input on this lathe or similar lathe would be appreciated, particularly with regard to the spindle bearings getting hot. If and when I need to replace the spindle tapered roller bearings, is it easy to find tapered roller bearings that would be an exact match in size?
