Powdered Graphite?
wizardofwood
Active Member
In a number of other posts I have seen powdered graphite recommended for lubricating flame lickers.
I am hoping someone can tell me where it would be available in Australia?
Or is it possible to use the 'lead' from a good quality artists pencil, maybe a 12B as that would have less binding agent and more graphite?
Try a good locksmiths, its often used to lub locks.
Jason
I find mine at the hardware store next to all the lubricants. You may also find some at an auto parts store. It should be fairly common.
Kel
I have seen it in auto parts stores. Also for larger quantities you may find it at a tractor dealer/supply. We use it to mix with seed to lubricate the planter.
SuperCheap Auto should have it, or Repco, Auto One - any of those places
Gasket makers usually sell it - sometimes known as colloidal graphite.
Best Regards
I found big bottles of it at Art Supply shops.
IronHorse
Ass a last resort, make your own. Stick a piece of graphite in the lathe chuck. Select the grade of paper for the fineness desired and sand away. When fitting pistons, I quickly have a pile on the lathe bed.
I tried locksmith's graphite with grease on a bicycle hub/cluster as antisieze ... not a good idea. I been using it on tailstock centre.
Ant
Being a tight wads I just use a good old 2B pencil, used to use powdered graphite but found i used to put to much on and if i need to lube the motion i usually use a tiny drop of diesel works OK for me.
regards Frazer
I bought this from a local hardware store for about $3.00USD
I may never live long enough to use that much of it! :D
A little bit goes a long way.
Rick
