My 1st IC Engine
ozzie46
Here is a video of my very first IC engine. It is a Mastiff Designed by L.C. Mason in England in the 70s. It is a flat 4cyl boxer 4 stroke.
I did away with the points and put in a Hall Effect ignition. Got the circuit form this board. From the thread " a new ignition circuit".
Ron
Ron,
A 4 cylinder for your first IC engine:eek:?
Wow, congratulations from someone suffering (well not really) through their first Single Cylinder IC engine.
Nice work.
Phil
Thanks Phil.
I guess I'm just a glutton for punishment.;D;D
Ron
Congratulations Ron,
It sounds like with a bit of fine tuning you'll have it running great.
gbritnell
Very nice engine especially for a first IC project! What other engines did make in the past?
What's in your sights for your next project? A V8 perhaps, it seems you have the skills for such a project. :rolleyes:
John.
Congratulations. Really nice engine. But a question.....What is that turning piece on top of the engine??
Barry
Thanks George, I need to make up a cooling system of some sort so I can run it longer. I'm using an RC carb on it now while I make the carb from the plans. I wanted to use a carb that I thought would work for sure to get it started in case the one I make doesn't work.
John, I have made a Paddleducks steam engine. It's a 2 cyl steam engine for marine use designed by John(bogstandard), and the chassis to a 5 guage steam locomotive of English origin called a Simplex.
Here is the thread.
http://www.homemodelenginemachinist.com/f31/start-long-term-project-7657/
Haven't been brave enough to tackle the boiler yet as my silver soldering skills need to vastly improve.
As fro my next project, I'm leaning toward the Edwards 5 Radial although I would like to do a V-8 eventually.
Thanks for the kind words.
Thank you Barry. The spinning thing is the magnet carrier for the Hall Effect ignition. The original design had the contact points in there. The Hall sensor is mounted on the side of the round piece. There is a cover that fits over this. This design had the rotor and distributor separate from the points because of the need to keep the height down so fit could fit in the hull of a boat.
Ron
Just for kicks there is the Wright Whirlwind 9 cylinder radial plans for free if you want to take a look for studying a more complex radial. Might be a little rich for your blood but definitely worth taking a look.
John.
John.
were can we get these plans
thanks Luc
Thanks for the answer Ron , now I see it.
Barry
Thanks John. Nice looking plans. They mentioned welding aluminum on the front engine cover. Not sure I'm up to that.
Ron
I wouldn't be worried about the welding part (you can have a welder do that), I would be more concerned if the project was too complicated for my skills.
It is a very involed project and don't feel bad if you think it's too much!
John.
Ron,
Nice work.
Phil
Phil is not suffering Ron, he is just looking for sympathy. Ignore him. He is building a great engine and enjoying the challenge.
And I am looking forward to seeing it at Cabin Fever next year.
Jim
That's the ticket,if you enjoy the challenge,all is good.
Ron
