Bob Wild
This thread is to describe my progress in building the above fire engine. I first came across the plans in a magazine article published in 1908 here http://www.john-tom.com/MyPlans/SteamPlans2/Fire Engine 1908/ModelEngineerFireEngine1908Small.pdf
If you look you will see the drawings leave a lot to the imagination. So my first challenge was to produce my own using Fusion 360. Attached is my progress to date. Some time later I came across a full set of plans from a French website drawn by a guy in New Zealand! So far I’ve started on the chassis and the front suspension.
One of the reasons for starting this thread is hopefully to get some help in stuff that is new to me. Starting with the leaf springs
a) How on earth do I form the 4mm eyes at each end?
b) The material used is spring steel. It is currently in the anealed state. What is the best way to harden an temper them?
I’m attaching a few pictures of my progress so far. Also a roller bender which I made and a proper drawing from the guy in New Zealand
