Ageless 9 and 18 Radial
rlo1
HMEM Supporting Member
Chandler, AZ
I am starting to build the Ageless 9 and 18 Cyl radial engines. I want to work these in parallel since many of the operations are similar between the two.
Made some progress this weekend and made a video of me running a cycle machining the flats on the crankcase.
https://youtu.be/782qzF6EGlc
Used a test block to dial in the settings for the thread milling. Took about 20 practice runs until the thread felt about right. I wrote a conversational gcode program to do all that machining at once at that 4th axis angle. All I need to do is to run it and rotate the 4th and repeat. Worked pretty well. It took about an hour for the mill to run the program on each cycle. I was not comfortable with editing the conversational gcode to add a "G0 A40" because the machine kept returning to A0 during the practice runs. So just to be safe I am rotating and re-referencing the A axis before each cycle.
Machined the intake manifold ports for the 18 cylinder crankcase. Whoever invented thread milling, thank you.
Cut 29 cylinder blanks (9+18+2 spares). Working on the conversational program for the first operation.
Spent the day setting up and running the 15L machining 30 cylinder blanks. This first op just profiles the lower 1/2 of the cylinder.
Great looking machine set-up but why don't you use a Face mill to machine the cylinder flat on the crankcase ? get rid of all those cutter marks and more likely leave a flatter surface.
Great feedback, I am planning on brushing the aluminum which should remove any tooling marks. I elected to use the same cutter for the cylinder hole and facing so that there is not a tool change. In retrospec, you are right and I should have loaded up a face mill for the cylinder flats.
If I stick anything in mouth that big its a Jaw breaker . Nice work on the radial .What machines do you have?
A small tramming error in the mill will translate to a large geometric error with a large diameter face mill.
The same error will translate into a potential sealing problem, but without the geometric error when a small diameter cutter is used.
Pick your poison. :(
