The first time I try to build the motor using machine tools.
The cylinder diameter 20mm
The piston stroke length 20mm
The compression ratio 6.
Air Cooling.
Splash lubrication oil poured into the crankcase.
Unfortunately we have in Russia is difficult to find for sale spark with thread >10mm.
Spark plug homemade, insulator of a glass tube of the thermometer. It has already been tested on two-stroke engine with a compression ratio of 6.
[ame="http://www.youtube.com/watch?v=2l_L1iwOUuU&feature=share&list=UUsk4uIzuwEg7kGK3q4kqAlg"] http://www.youtube.com/watch?v=2l_L1iwOUuU&feature=share&list=UUsk4uIzuwEg7kGK3q4kqAlg[/ame]
At the moment, it remains to make: connecting rod, piston, camshaft, lifters, rocker arms, timing gears.
And also milled crankcase.
Air Cooling.
