Here are some pictures of my Midget engine. It has an 1-1/4 inch bore and is built from castings. The first part of the magazine article had drawings for making the patterns for the Crank case halves, the Cylinder, cylinder head, Cast Iron flywheel, brass connecting rod, venturi, and timer points bracket. The rest of the parts are machined. It would be pretty easy to machine the cylinder and piston from bar stock.
Quite a few of these engines have been built and they do run pretty good.
