hi folks: As a frequent lurker and learning much from the HMEM community I wanted to share this project. Its not exactly a working engine but it is a working breech loading cannon and was made in the absence of any plans, pretty much by extrapolating from photos and a local cannon I could take measurements from. In fact it is remarkable that in this day and age you still cant find working drawings for a cannon that went into service in 1904, presumably as someone, somehere might make a version with the 6000 yard range of the original. As this cannon was really the backbone of the commonwealth First World War mobile artillery and like the Lee Enfield a mainstay weapon I wanted to complete it for 2018 as homage to the centenary of the completion of WW 1, but things don't always work out on time and it turned out to be a very complex project. Its no exaggeration to say there is hardly a straight line in this entire piece. No doubt the folks who are into solidworks and other modelling with print and c and c capablities could model this , I did it like my late Grampa, by cutting , eyeball and hand fitting for the most part with some crude hand drawings.As a result those of you who know this piece will recognise some cartoonish features, the barrel is too short, the wheels are too big,the sights are too wide and the breech is about twice as long as it should be . But everything works, elevation, traverse, brakes, all the little hatches open, breech recoils on a spring operated recoil tube, gunners seats are moveable, the Wellin style breech block has a 1: 2 90 degree bevel gear which rotates the breech block 90 degrees as you traverse the handle 180 degrees (that took 2 tries to get right) . There is firing rod right through the middle of the breech block which fires a plastic toy cap on a brass nipple in the breech when you tap it with a hammer, the barrel was made with a .120 inch steel brake liner for the bore. This is a cap firing toy that cannot chamber or fire ammunition of any sort, not a firearm for those in sensitive jurisdictions, but its kind of satisfying to hear a little snap and then watch a little smoke waft from the breech when you open it up.
