- Jun 28, 2011
- 238
- 480
Well I thought I would share my version of a power feed for my mill.
I cant spend the money it takes to get the mfg's feed so after reading a lot about other homemade power feeds here and around the net, this is what I came up with so far.
The motor/gearbox was from all electronics for $25 with shipping : http://www.allelectronics.com/make-a-store/item/DCM-563/12VDC-RIGHT-ANGLE-GEAR-HEAD-MOTOR-WITH-WORM-DRIVE/1.html
The future motor controller is from ebay for $9 and .90 cent shipping ! : http://www.ebay.com/itm/151088811500?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_4788wt_4102
The power supply will be from a computer monitor at 14V and 3A about $6
Right now its an old train transformer that is really pushed to its limit ( it gets pretty warm !! )
I drilled the mill feed screw to accept a piece of delrin rod that i pinned to the feed screw and pinned a 14mm nut on the opposite end. I cut the motor output shaft and milled it down to fit in the 3/8 drive 14mm shallow no name socket. I just slide it back and forth to engage and disengage the power feed. The socket and delrin extension wiggle around a little but that allows for any slight misalignment of the motor and feed screw. I tried a more rigid setup at first but I found it would bind up a little here and there as the table moved from one stop to the other
The original plate on the end of the table was replace with a .160 2024 T3 aluminum plate and I turned a few bushings out of old brass faucet stems and 4 pieces of 10-24 threaded rod go from the outboard plate of the motor to the aluminum plate with locking nuts.
I had to rout out room for the two upper nuts on the end of the mill's table.
I have run a couple of cuts with it and the control is good, the finish is better that when ran by hand and the return speed doesn't make me wait forever !
When the other items arrive i will replace the cheesy speed tape chip guard with a box of some kind that will hold the switches and control.
here is the video, its cutting .050 off a 7075 T6 part for the crosshead guides of my steam engine
https://www.youtube.com/watch?v=FGcqeq4gUys
Pete
[ame]http://youtu.be/FGcqeq4gUys[/ame]
Pete
