- Jun 24, 2010
- 2,361
- 932
I've been trying different valve cage configurations on my radial & going to have to make a decision & live with it soon. The head has a hemispherical shaped combustion chamber. The valves enter at a specified angle, so that's all locked down in the design.
The assembly method calls for machining the cage with a perpendicular edge, so its basically like a squared off sharp edged tube. The cage is permanently inserted into the head, then the valve seat cut with a 45-deg tool, then lap as necessary for final seal. This allows for any slight distortion of the cage to occur before cutting & dressing the seat. The cage is now permanent so if seat is buggered up or seal can't be achieved , then frowny face. This method has been documented by better builders than me in other posts, but my question is more about the assembly final layout.
With the hemi head & valve angle / placement geometry its hard to get the valve totally flush. I've tried to strike the happy medium so one valve edge extends slightly into the CC dome. The opposite side is inside a bit. What I'm concerned about is the resultant open space nooks & cranny's, specifically where combustion debris can potentially build up. Hopefully the sketches illustrate this.
I could make the cage+valve stick entirely into the chamber. I've seen that done on another engine. That would keep crud buildup to the outer area of the cage, ie harmless. It would increase the CR a bit but mostly I'd have to check for piston interference. Another radial that used that method have relief arcs cut into the top of the piston.
Looking at real heads, they come in all flavors but generally they have a smooth profile kind of transitioning to the seat area. I could Dremel some of this profile, but not near the outer edge where there is a lip in the head.
Any comments or opinions?
