Peewee V4 Plans Update
stevehuckss396
Model Engineer
HMEM Supporting Member
Sterling Heights, MI
Hello!
I have had sent to me a list of bugs for the Peewee and those issues have been addressed. Peewee 1.02 has been sent to a few who are currently building the Peewee. It made me wonder if there is anybody else out there with any issues with the drawings. I would like to hear about anything no matter how small. Missing dimensions, unclear details, misspellings of any kind, anything at all.
Report them here and i'll get all issues cleaned up and have a fresh set very soon.
Steve
Hello!
Steve
where do we get plans ??
Luc
Luc
The plans are part of a package. You get the plans when you purchase the castings. When I built mine I documented some things that I found to be incomplete and made some changes like the way the camshaft is made. I used the same fixture but changed the way the fixture is used. When the project was finished an updated set of drawings was produced. As Bob Shores, the designer of the Peewee has passed away I have made myself responsible for the maintenance of the set I produced as the original set will never be updated. The changes are sent to Dirk to provide with the castings and keep builders up to date on the latest set.
DSCN1765s.jpg~original
Hello Steve!
I have purchased the Casting from Dirk and together with the original drawings he also sent a set of one revised by you.
After reading your post I checked which version I have and found the it is Revision 1.00 Date 03-01-2012.
Please could you send me the revision 1.02?
Thank you.
Edi
Hello Steve!
Thank you.
Edi
Hello Edi! I have sent the updated version to Dirk to update all the builders. I would prefer you get them from him. As I do not know who has purchased the castings. I don't feel comfortable sending them out. I did send them to 2 builders but both have started build logs and I wanted both with active builds to have the latest set as soon as possible for obvious reasons.
Steve ;
so building one of those from stock is not possible ??
Luc
Steve ;
Luc
I am pretty sure Dirk will not sell just plans as there are no outer dimensions for the block, heads, and bell housing. The drawings are incomplete for a bar stock build.
Hi,
I' m very new in this forum. Where do i get castings and plans ?
