New member
Grey
New Member
New member,
Grey Norton from Southbroom, Kwa Zulu Natal ,South Africa
I began machining in 2011 on my retirement from farming . I would be very grateful if someone could. advise me how to wire up my Emco Maximat Super 11 lathe .The single phase 220 volt rotary switch has burnt its contacts and it used to ”switch on”then select “ high or low speed” and also select “ forward or reverse”.All this was done with one very expensive switch . I wish to replace the single rotary switch with 3 or 4 separate switches if this is possible ?Could some one please advise me if this is possible ?With thanks Grey Norton ,Southbroom,KZN,Southbroom ,South. Africa
Welcome !
about switch , I think you can change it but I've never used a lathe like yours so can't give a specific way
PS : I edited your post - added the switch question you asked in another thread.
