Need your help for RC hobby and the FAA
SmithDoor
Staff member
Global Moderator
Clovis Ca
We asking to the FAA to give a Exemption for fix wing model to up to 2kg
Please read and sign our petition
http://chng.it/LM9VBT2nmr
Change.org
Thank you
If can email here list thank you
https://www.whitehouse.gov/contact/
https://www.ap.org/contact-us/contact-newsroom
[email protected]
[email protected]
Exemption for model aircraft fix wing from currant FAA limit 250g 0.55pounds limitation as stated in the FAA ruling ( Unmanned aircraft that weigh 0.55 pounds or less on takeoff, including everything
that is on board or otherwise attached to
the aircraft.)to 2kg built of at least 50% by weight using balsa wood, foam and or covering materials.
Still limited to a maximum altitude off the ground to 122 meters.
Speed limit to 48 knots.
Only for non commercial uses, hobby use only.
Not for multi rotor drones with or without cameras still limit to 250grams per FAA.
Definition of Model Aircraft
Built from tradition building materials (wood and or foam with covering)
Does not need a gyro to fly
Fix wing design .
Typically made at home
Does not have camera to fly.
Flies line of sight only.
Definition of a Aircraft Drone
Has multi motors
Needs more than 3 motors to fly.
Needs a gyro to fly
Primary made from plastic
Typically flies by a camera
Typically ready to fly.
More data at Looks like the AMA is not on the new Drone Advisory Committee - RC Groups
