tevans9129
Does anyone know what the MT of an old Rockwell 10" lathe is? I have the manual but cannot find the info in it.
Thanks for the info Martin...it is not a MT 2 in the spindle as there is a sleeve that reduces to a MT 2. much larger but not a MT 3 as it is also too small. Perhaps a 4 or 5 and I have found the specs so hopefully will be able to compare.Hi,
Try a google search there is a lot of information out there.
I found this :-
https://www.mdna.org/images/File/files/5864.pdf
The 10 1/4 " says it is a MT 2.
I hope that helps.
Martin
Yes it isThe one a lot Lathe Manufacturers used Jono tapper (jono may be missing spelled)
No 9 Brown and Sharpe?
That's what Lathes Co uk hints
Of coiurse that is what would come out of the factory and if there are doubts about getting one without much proper tooling-- who knows now
You may be correct Tim, I admit to being ignorant in my understanding of the data in the Machinery's handbook but I have not been able to find anything with the dimensions that I have with the adapter.My paranoia says: if the lathe came with an adapter, there's a chance that the actual taper is a Rockwell WTF. There's no rule that says the manufacturer has to cleave to any standard; if no one was going to use the un-adapted taper but them, there's little impetus for them to use a standard.
I checked these in MH but none seem to match the adapter that I have. Thanks for the suggestion.The one a lot Lathe Manufacturers used Jono tapper (jono may be missing spelled)
That seems to be the closest to the adapter that came with the lathe but does not match up precisely in the MH at least with my limited knowledge. Thanks for the response Chris.I had one of those lathes and I vaguely recall the headstock bore fit a 4C collet. Tailstock was MT2.
I tried but was not successful so gave up.Lathe head stock tapers are usually shorted sections of standard tapers. South Bend uses Morse (I have spindle adapters for Morse centers and 5C for the 13" and 1-A / 3C for the 9"), other makes may do the same or use other standard tapers.
Grab you adapter, your calipers and Machinerys Handbook and work out what it is.
I should be pleased if you will confirm or correct the information on the lathes.co.uk site which I accessed on your behalf
Norman
Particularly well-engineered, the headstock held a heat-treated and ground spindle with a bore of 15/16" and a (4C) collet capacity of 3/4". It ran in a large, double-row angular-contact, pre-loaded precision ball bearing at the spindle nose end and a "floating" bearing at the outboard end designed to compensate for spindle expansion as the machine warmed to its task. According to the sales literature the spindle was bored with a No. 9 Brown and Sharpe (B & S) taper and fitted with a short, hardened bush to take a No. 2 Morse taper centre. However, it is possible that later lathes may have been modified in this respect and the nose bored to the more common Morse standard. The ground-finished spindle thread was 11/2" x 8 t.p.i.
