Without having a factory of specialized precision equipment, even if you do the very best you can, there is still quite a bit of luck necessary to be successful. Any seals that are utilized such that they are compressed during each stroke are not likely to work. At least for me. Starting with a factory pump element removes a lot of the stress of building the pump. I tried a couple of factory elements and the fit and finish, and the FUNCTION, was so much better than anything I built myself. And if it helps you get your engine working, that is a whole lot better than endless frustration and lost time. Just my opinion.
