I don't have DRO's on my mill, and I DO lay everything out. I always use an edge finder and the positioning dials to position work as I mill it, but my layout confirms to me that I have turned the dials the correct number of turns and partial turns. I use red or blue Dyekem layout dye--not aerosol, because its too hard to control, is wastefull, and it stinks up the house. I use the cans that have a small brush attached to the inside of the lid. I bought a height gauge when I first started into this hobby, but find that I never use it. I use two sizes of digital Vernier style calipers, a 4" and a 6". I have a small set of three 90 degree machinists squares, a scriber, a 6" steel rule thats about 1/2" wide, an "automatic" prick punch, and an old drafting compass with two steel points in it. I use automotive laquer thinner to clean up any unwanted layout dye after the fact. I have a couple of old plastic protracters, but seldom have to use them. I have a mill vice that will rotate thru an angle up to 45 degrees, and a digital level/protractor that reads out in tenths of a degree. That seems to be everything I need. I have built 14 steam and gasoline engines, and half a dozen zany things to run with these engines, and the equipment listed above has served me very well.---Brian
