Just a general question:
If a model engine is designed for using air-cooling fins, or, for a water jacket, can either method be used?
I have noticed many old, Hit and Miss engine designs using water jackets/tanks mounted to the cylinders. Many small, air-cooled vertical, 4-stroke engines use air cooling, but can also sometimes be built using a water jacket. So, does it matter how the cylinder is cooled off? Is water more efficient in carrying away extra heat? Are actual fins necessary, or can a hunk of Aluminum, profiled to the called for dimensions, be mounted onto a cylinder without the fins being machined into it? I would imagine that fins add surface area for better cooling efficiency, but are they necessary. How about just increasing the size of the "heat-sink", and forget about machining plunge-cutting/sawing cooling fins?
Let's take for example, the popular Nemett-"LYNX". The drawings call for some cooling fins on the cylinders. Why? Can I just machine a donut-shaped piece of aluminum, having the same size, and shape as the original set-up, but without the fins?
Just wondering....
Frank
Just wondering....
Frank
