rklopp
- Oct 6, 2008
- 393
- 109
Here are a couple of photos of the "Clanford Clan" I built to plans published by Ron Chernich on ModelEngineNews.org. It runs, albeit SLOWLY. I think this is mainly because the piston fit is still quite tight. I deviated from the plans by substituting ANSI UN threads, some imperial dimensions for SI, making the conrod a little narrower, and whittling the venturi/tank top out of solid Delrin acetal. It starts with finger flipping, no spring starter required, as some web postings would suggest. The running is almost totally insensitive to needle position, so I may re-engineer that. The bore is 6.5 mm, stroke is 7.5 mm and displacement is 0.24 cc, or 0.015 in^3. Next on the agenda is a couple of 0.1-cc "Nano" "Diesels." Even though their displacement is less than half that of the Clan, the bore and stroke are both 5 mm, so not that much smaller than Clan's. I built Clan on comparatively beastly machinery: Monarch 10EE lathe (and Colchester Chipmaster for driving the bore lap), Deckel FP2NC and Aciera F4 mills. I used a 4X magnifier a lot.
