Due to my absolute hatred of set screws on shafts, I also did the flywheel with my version of a taper lock bushing.
THANKS!Hi David, It certainly manages the quick changes of gear! Do you plan a boiler and boat? - or is life easy enough (!) just making engines??
A great job. well finished and sounds sweet - with no clattering! Proof of the care you have taken.
Well done!
Thank you!You have done something to make your Dad proud! Run it often and think of him and what you did together. This engine is one of those.
My mate is an ex-toolmaker and abhors my "lack" of precision. So I appreciate what you have done - beyond my skill.
Well done!
I was interested in your personalised taper lock bush. I was recently machining a 3 throw crankshaft from 1.75" solid instead of the 'Lego' kit construction suggested by the drawings. I left an oversize flange at the flywheel end but needed a similar flange on the free end for locating the centres of the crankpins during the offset machining (I know - I should have left a flange on that end as well, too late!)Due to my absolute hatred of set screws on shafts, I also did the flywheel with my version of a taper lock bushing.View attachment 122947View attachment 122948
Anyway, I discovered a supply of miniature taper lock bushes which are available down to 1/4" dia and fit into a parallel bore. They only cost peanuts so it wasn't worth the bother of making my own design. They go by the name of Translock, grip really securely and are available in Imperial and Metric ranges. I guess you older hands know of these but, despite using very large Taperlocks in years gone by, I had never realised that there were miniatures available.
Thank you Joe! It was a really good exercise in design modification, fixturing, and machining. Kept me off the street for a LOT of hours. 8>)David, thanks for sharing with us, that is one good looking engine, great workmanship and runs great, you have to be proud of that one, thanks again, Joe
When I was a very small kid (last week), my Dad poured and scraped some babbits. I asked what he was doing and he told me. But in all my life, that is the only time I ever saw anyone doing it. I have since wondered what the exact composition of babbit is. Does anyone know?My dad got a Stuart Twin Launch kit as a retirement gift when he retired in 1980. He put together a small shop over a couple years, and barely started the work on this, but he passed away in 1984. I got the kit about 4 years ago planning to finish it one day.View attachment 114030
Well, I have now started on it. My dad had only completed the base plate and main bearing caps, so not much was done. His long time work on all types of old engines led him to add Babbitt main bearings to the build. Somehow, he got the babbit off center, so the bearings are not constant babbitt thickness. I was thinking of getting some Babbitt and re-machining the castings, but upon removing the caps and looking at it, the bearing surfaces are really good, so will use as is. The 5/16 shaft turns easily and smoothly! Will have to do a lot of clean up and finishing of the base casting.
This will not be a build log, but will post mods and unique methods of fabrication. His kit did not include the reversing gear, so I will be making all that from scratch.
you got that right about "shocking" Stuart drawings. I have to admit, I wasn't "schocked", I was PISST! Frankly I thot these drawings were unbelievable. It would take so little effort to correct them yet it is not done.Nice shop! Wish I could keep mine that clean. I put 3 axis DRO on my mill as soon as I got it. Had the lathe for a few years before adding the DRO, what a difference! I "grew up" running machines years before DRO's were even a thing. Quite a few years "dial counting, then Trav-A-Dials came out, that was an improvement, then the first DRO's a year or two before I moved into engineering and design.
After decades of design work, first look at the Stuart drawings was shocking. I have done CAD models and drawings of the parts I am making from scratch. The Stuart drawings are basically "Make it kinda like this." 8>) I thought of 3d modeling the whole engine, but that would take quite a bit of time, not sure it would be worth the effort, but would make design upgrading easier.
There are several grades of Babbit. Most common ones consist of Tin, Lead, Copper, and Antimony.When I was a very small kid (last week), my Dad poured and scraped some babbits. I asked what he was doing and he told me. But in all my life, that is the only time I ever saw anyone doing it. I have since wondered what the exact composition of babbit is. Does anyone know?
Not only are the parts poorly dimensioned, some wrong, some missing dimensions, and NO tolerances given, but there is no assembly drawing. For some reason the parts have numbers in the corner, as if they are going to be referred to, but the assembly drawing has no references, and is missing detail. Glad I spent years on a drawing board, and many years on CAD designing machinery, was able to figure it out relatively easily. I imagine someone without a lot of experience having a very hard time making anything precise.you got that right about "shocking" Stuart drawings. I have to admit, I wasn't "schocked", I was PISST! Frankly I thot these drawings were unbelievable. It would take so little effort to correct them yet it is not done.
