vederstein
Must do dumb things....
- Feb 26, 2011
- 918
- 745
I was continuing to think about this engine that GG created.
First of all sir, congrats on such a cool design and without any plans! So what I say isn't any type if criticism on your work, I'm just pondering ways of making engines more thermally efficient.
There's a company that's working on a crazy efficient opposed piston two stroke diesel engine. Per the video below, properly outfitted, they're approaching thermal efficiencies of around 50%. This is phenomenal!! (For example a gasoline engine in a car is about thermally 25% efficient. A nuclear power plant about 35% efficient. A steam locomotive about 5% efficient.)
I was thinking of an addition to this engine and again it's not a new idea. In fact, this idea was used in WWII aircraft engines: Water Injection. Just after ignition, inject a small amount of water into the engine. The heat of combustion will then not only push the pistons apart, but will create steam to push on the pistons as well.
The balance would be to inejct only enough water to counteract the amount of heat removed via a traditional water jacketed cooling system. What I'm envisioning would have no cooling system. What is currently waste heat would be converted to steam to push on the cylinder creating power.
Also, If the engine could run about 150 celsius with the exhaust the same temperature, opportunities abound for weight reduction. There are industrial plastics that can easily withstand these temperatures which would replace what are now metal components.
Comments?
...Ved.
Comments?
...Ved.
