3" Rider Ericsson running not complete.
propclock
Engine builder, Blown V8 to wobbler, Love it all.
HMEM Supporting Member
Crockett calif
I was gifted these castings and decided to tackle this project. It was a challenge due to the size.
Very little fit in the mill vice and table clamps used a lot.
The 13" flywheel was at the limit of my lathe a 10ee . the 7" cylinder was also a challenge because I have no steady rest for my lathe.
Fortunately a friend loaned me a tool post grinder and I managed to get a nice bore for the power piston.
These are just first run videos . any questions just contact me. I plan on making it living room beautiful with a good paint/polish
because I have no room in my zone. The engine pit.
https://youtube.com/shorts/1MmcVJ5NVNY
https://youtube.com/shorts/aKMa1WHlFT0
youtube link plus bla bla
Well, things I learned from final long term runs. The Hot tube is in direct contact with a propane burner and my silver soldered cap to the tube failed repeatedly.
All my fault. I use mapp gas and don't get hot enough but with two torches I get close enough(not). Finally I realize I don't have enough metal overlap at the joint.
But I try 3 or more times. I finally realize I need to switch to brazing. and a mere 2 more brazing tries I finally have an air tight hot tube. My other delay on a final
quality engine was the main cylinder to water jacket seal . I don't like to press fit a cylinder previously ground true into a under sized bore only to distort the cylinder.
So I used my favorite epoxy. But I didn't use enough. So I had to inject epoxy with the engine held upside down into the water jacket cylinder area and again reversed
in the normal orientation. Finally the 2 major problems from shakedown run 1 solved. Now just a bigger water pond and improved spray head .
Also I tried aluminum cans for a displacer piston. Not strong enough. I guess the hot tube is realy HOT. So I reverted to 1 steel soup can and 2 tomato sauce steel cans silver soldered together.
Together they make up the 10&3/4" displacer piston. Enough bla bla.
