Which project for a Sherline mill and lathe
Discussion in 'General Engine Discussion' started by Harry Mueller, Dec 26, 2018.
  1. Dec 26, 2018 #1
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    Hello folks,
    I have in my possession a Sherline mill and lathe, very little experience in running them and a very real desire to build an IC engine. I've acquired Plans for the Webster and the ML Midge with a hope to perhaps eventually building both.
    In playing with my Sherline equipment I've noticed some definite limitations due to its small size. For example, I wouldn't be able to turn the flywheel of the Webster on the lathe although a possible work around might be possible on the rotary table.
    My question is, has anyone built either of these projects with Sherline equipment? Or might there be more suitable projects for a beginner with these machines?
    Thanks,
    Harry
  2. Dec 27, 2018 #2
    kuhncw
    kuhncw
    kuhncw
    Well-Known Member HMEM Supporter
    Apr 13, 2008
    598
    73
    USA ILLINOIS
    Harry,
    Sherline sells a riser block set that would give enough swing to accommodate the Webster flywheel.
    Chuck
  3. Dec 27, 2018 #3
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    Thanks Chuck, that part is on my wish list. However, the maximum diameter that can be held in any of the Sherline chucks is 2 3/4". And then there is the issue of the fairly short cutoff tool.
    Many years ago my wife gave me a Bob Shore Hercules engine kit and I'd like to gain some experience on a bar stock engine build before tackling the castings. If someone else with Sherline machines has built either of these motors, or any other similar simple project, I'd love to hear about it.
    Harry
  4. Dec 28, 2018 #4
    kuhncw
    kuhncw
    kuhncw
    Apr 13, 2008
    598
    73
    USA ILLINOIS
    Harry, there is a small hit and miss engine designed by Dave Kerzel. Flywheels are 3.5 inch dia.
    http://www.floridaame.org/GalleryPages/g1h0106.htm
    Also there is the Tiny designed by Arv. Flywheels are 1.75 dia. https://www.homemodelenginemachinist.com/threads/tiny-i-c-engine.7397/#post-80612 Hopefully the link works.
    You might get around the Sherline chuck work diameter limit by mounting your flywheel blank on an arbor or by making a faceplate fixture of some type to hold the flywheel blank.
    Chuck
  5. Dec 28, 2018 #5
    editor123
    editor123
    editor123
    Active Member HMEM Supporter
    Dec 17, 2016
    42
    11
    You might consider building Humbug, a 1.47cc model airplane engine as either a glow plug or diesel. It was designed by Ron Chernich specifically to be build on Sherline-sized equipment. I built the model used for the example in the article on my Sherline mill and lathe. The extremely detailed build instructions assume the reader has limited or no machining experience and so the article series takes from issue #21 of Model Engine Builder magazine through issue #27. Am I tooting my own horn? Absolutely. But the article is the most detailed instruction set ever created for machining an engine out of bar stock. www.modelenginebuilder.com for further information.
  6. Dec 28, 2018 #6
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    Thanks again, Chuck. I've downloaded both sets of plans and will look at them. I noticed in the build notes, David suggests his motor is not a beginner's build but perhaps a third project after an air engine and a stirling. Well, I've got 2 air engines on the go and plans for a stirling that might work with my Sherline equipemnt.
    The Tiny is likely perfect for my equipment but perhaps a bit too ambitious for my present level of machining expertise. I will study the plans to see if its a feasible project for me.
    I do like both engines. :)
    Harry
  7. Dec 28, 2018 #7
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    Thanks, I'll certainly take a look at that. I'd prefer to build something under .08 cu inches since I have an unfinished model in the rafters that would host a smaller glow/diesel engine. However this project looks ideal for what I want to do. Got me thinking again. :)
    I did a search on the website and it looks like the engine build is from issues 21 to 26, 28, 29.
    Harry
  8. Dec 28, 2018 #8
    crueby
    crueby
    crueby
    Project of the Month Winner!!! Project of the Month Winner
    Mar 9, 2010
    594
    693
    The headstock on the Sherline lathe also can be rotated 90 degrees so the flywheel would hang off the back of the bed - I used that to turn a large flywheel a couple of times.
  9. Dec 29, 2018 #9
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    That got me looking and I found some info on turning the mill headstock 90 deg to do the same thing. Loads of ways to do something. Looks like almost anything is possible given enough imagination. :)
    Harry
  10. Jan 20, 2019 at 8:34 PM #10
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,245
    253
    This it is is pretty much true of any set of machine tools. That is there is more than one way to do something.
    Honestly I get more satisfaction from learning how to machine than I do with the completed project. Of course my completed projects are simple tools at the moment.
    Which brings up another point, if you don’t have any machining skills hold off on trying to make an engine! That might be frustrating but building up skills on cheaper projects makes a lot of sense. This is specially if you make tools that will last you a lifetime.
    Some beginners projects include:
    1. Prick punches and center punches.
    2. Dowel pin punches.
    3. Tap wrenches
    4. Tap follower
    5. Die stocks. Including a guided stock for the tailstock on a lathe.
    6. Clamp sets and accessories for setup.
    This list could go on and maybe others will add to it. The point here is to pick a few projects to develop skills on and produce something useful so that you are not wasting your time. You want to learn how to select operating speeds, tools and other setup needs to execute a project. You goals would be holding tolerance, getting good surface finish and having the right order of steps.
    Another skills builder is toys like a thumb engine. Again the goal is to build confidence before starting in on an expensive bar stock build. The reality is this everyone off s has had is embarrassments (if that is the right word) when making stuff. Becoming familiar with the tools and technology on simple items makes it less likely to screw up a you first engine though that happens too.
    Screw ups are so easy to make that it really frustrates you when it happens. Just about a week ago I was making ups tool holder for an old lathe quick change tool post and screwed it up just enough that I wanted to chuck it through a window. I blame that on being call out to the production floor in the middle of the project. Crap happens I guess but the point is it is very easy to make a part so it will not fill its intended purpose. Sometimes it is a simple issue of experience.
    canadianhorsepower likes this.
  11. Jan 21, 2019 at 3:45 AM #11
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    Thanks Wizard69, good suggestions. Some tools that I might actually use myself would be a gratifying build and are certainly part of my plans.
    Since I posted the initial question I've been busy and have had some moderate successes. I actually feel there is hope for me and my confidence is growing daily.
    I've completed a little air engine called the "Rocker engine" and it runs very nicely on a little compressor. I've also got two wobblers nearing completion, one called a "David Steam engine" and the other a fairly generic wobbler design that I've changed up a bit to expand my experience. Both might be tested on air tomorrow. Next up will be a Stirling motor.
    In addition, I've started machining the frame for the IC Tiny. Not sure if that motor is within my capabilities at this point but it's so small that material costs are not much of a factor should I fail.
    I just put in a fairly substantive order with Sherline to expand the capabilities of my equipment to handle my ultimate goal; the Bob Shores Little Hercules.
    I must say I'm enjoying this hobby much more than I thought I would and kind of wish I had started earlier in trying to gather some machining skills.
    Harry
  12. Jan 21, 2019 at 2:37 PM #12
    dethrow55
    dethrow55
    dethrow55
    Dec 24, 2015
    50
    8
    Gender:
    Male
    Occupation:
    retired draftsman
    el paso texas USA
    hello harry i have a taig mill and lathe somewhat similar to a sherline. ive been making a lotta tools and learning how to do setups various measuring setups. i also want to build ic enginees start small and work up as skills increase. oh also have a unimat . i search the web for small tools and cool items to make amassed a lotta of drawing and pics of tools to make. just a few items ive made 1.jpg 1.jpg
  13. Jan 22, 2019 at 2:18 PM #13
    lbarnett48
    lbarnett48
    lbarnett48
    Len
    Sep 25, 2017
    2
    6
    Harry, I too have a Sherline Mill and Lathe. I use the lathe a lot for small things. I do have a large floor mill and a larger lathe. I found the Sherline mill not ridged enough and the cuts would tend to be choppy. However, I am working on a project now that would do well with the Sherline. It is the J. Jonkman Sterling 60. It is a very nice looking engine and the plans are available online for free.
  14. Jan 23, 2019 at 1:26 AM #14
    Harry Mueller
    Harry Mueller
    Harry Mueller
    Aug 26, 2018
    7
    0
    Gender:
    Male
    La Salle, Manitoba
    I had downloaded the plans for the Sterling 60 earlier but thought the project was beyond my capabilities. I also wondered about sourcing some of the materials required. But your post has piqued my interest again and I think I may consider it after my two successful builds. It sure is a beautiful engine.
    Harry
  15. Jan 23, 2019 at 10:46 PM #15
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,245
    253
    That Sterling 60 sounds interesting. I've been working on trying to get a machine shop up to the point where I can actually make something! Unfortunately seems like something is always turning up to take funds form shop building. Thus right now I have a lot of interest in "Easier" lathe builds.
    As for the Sherline mill, every machine has its niche.
Share This Page
