What to do with copper rods?
Discussion in 'General Engine Discussion' started by winklmj, Aug 3, 2010.
Help Support HMEM by donating using the link above.
  1. Aug 3, 2010 #1
    winklmj
    winklmj
    winklmj
    Nov 23, 2009
    171
    2
    At the scrapyard I grabbed up a few 1/8 to 1" round copper rods anywhere from 6 to 12" long--at the time I thought they were brass (newb mistake). Copper any good for anything other than plumbing fittings? I know they're machineable because some of them have obvious signs of being turned on a lathe (bored on the ends, center-drilled, etc...). Copper durable enough to be used in place of brass or too soft?
  2. Aug 3, 2010 #2
    kcmillin
    kcmillin
    kcmillin
    Project of the Month Winner!!! Project of the Month Winner
    Jan 20, 2010
    1,193
    36
    I have seen copper used in 90% of boilers made on this website.
    Just a thought.
    Kel
  3. Aug 3, 2010 #3
    mklotz
    mklotz
    mklotz
    Aug 29, 2007
    3,039
    17
    Copper with signs of machining? Sounds strange given the fact that copper is such a bear to machine. Are you certain they are copper? Some of the marine brasses/bronzes have a reddish color close to copper.
  4. Aug 3, 2010 #4
    winklmj
    winklmj
    winklmj
    Nov 23, 2009
    171
    2
    Hmmmm, they do have a reddish tint to them--very obvious when I got them home and compared them to some brass I had. Hopefully they are more brass/bronze than just copper.
  5. Aug 3, 2010 #5
    Troutsqueezer
    Troutsqueezer
    Troutsqueezer
    Aug 8, 2009
    930
    11
    Seems like solid copper in 1" round and 12" in length would be worth quite a bit of money.
    -T
  6. Aug 3, 2010 #6
    Jasonb
    Jasonb
    Jasonb
    Mar 30, 2008
    2,264
    396
    Bronze would be worth more :)
  7. Aug 3, 2010 #7
    Noitoen
    Noitoen
    Noitoen
    Dec 26, 2008
    621
    11
    Copper used in spot welding electrodes machines quite well, at least it's what I see at a friends machine shop. They make all kinds of electrodes for the auto industry.
  8. Aug 3, 2010 #8
    Deanofid
    Deanofid
    Deanofid
    Jul 19, 2009
    2,673
    10
    Most copper does not machine well at all. It's usually quite miserable to make a nice finish. Like
    trying to turn chewing gum. That doesn't mean it can't be done, since it's accomplished every day
    in industry. We used to get a job turning copper now and then in a shop where I worked. I've forgotten
    tool geometry now, but remember we used whole milk as a lube.
    Hopefully, what you got was some kind of bronze, like Marv says. You could actually use that for
    something in regular model making chores. Copper has kind of a limited use for most of us. Rivets,
    boiler stays, and stuff like that, but I wouldn't want to make a piston or cylinder from it.
    If what you got was copper, trade it to someone for some nice brass.
    Dean
  9. Aug 3, 2010 #9
    Kermit
    Kermit
    Kermit
    Guest
    The cutting properties of copper can be improved significantly by creating an alloy with half a percent of tellurium. This produces only a slight alteration in the electrical and thermal conductivity and ductility of the free machining copper. Copper telluride precipitations in the microstructure break up the turnings into chips and enable a much higher machining speed than is possible with pure copper. On a machinability rating scale with 100 being for free cutting brass and 20 for copper, tellurium copper is rated at 90.
    Alloy 145
    Kermit
  10. Aug 3, 2010 #10
    Deanofid
    Deanofid
    Deanofid
    Jul 19, 2009
    2,673
    10
    So, how do you add tellurium to your copper rods? Just rub a little in, like lotion?
    ;D ;D
  11. Aug 3, 2010 #11
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    967
    27
    Lotion Rof} Rof} Rof} Rof} :big: :big:
    We use to have a spot welder where I worked which too I believe .5 rods but I do know I've also machined pure copper for electrode racks for our process line. They are used for hard coat anodize and electro polishing. Those rods where 1.0 dia and 6 feet long. The racks we built were about 10 feet long by 5 feet tall, basically a big picture frame. And yes copper is not an enjoyable material to machine.
  12. Aug 3, 2010 #12
    GWRdriver
    GWRdriver
    GWRdriver
    Senior Member
    Jan 22, 2009
    715
    85
    Otherwise known locally as Unobtanium.
    ;D
  13. Aug 4, 2010 #13
    Kermit
    Kermit
    Kermit
    Guest
    NO. Nothing so difficult as that. Just increase the amount of paper money paid and let the 'jokers' at the foundry do it for you.
    8)
    My point being that a copper rod that is 'easy' to machine has a higher than average chance of being just such an alloy. Silly boys.
Share This Page
