What kind if splined shaft is this ?
Discussion in 'Tips and Tricks' started by Anatol, Aug 25, 2018.
  1. Aug 30, 2018 #21
    Anatol
    Anatol
    Anatol
    Jan 22, 2018
    249
    39
    Gender:
    Male
    Los Angeles
    Interesting idea, thanks
  2. Aug 30, 2018 #22
    TonyM
    TonyM
    TonyM
    Well-Known Member Project of the Month Winner
    May 15, 2017
    189
    111
    Gender:
    Male
    Occupation:
    Retired
    North Bohemia Czech Republic
    It's called an involute spline. Made to reduce stress points and give greater strength than a square form spline.
    This half round form is probably a Wildhaber Novikov gear
    Anatol likes this.
  3. Aug 30, 2018 #23
    bazmak
    bazmak
    bazmak
    BAZMAK HMEM Supporter
    Dec 12, 2012
    2,128
    1,180
    Could the male and female shafts be drilled together and when taken apart pins fitted to the male
    to form the splines ???
    Anatol likes this.
  4. Aug 30, 2018 #24
    TonyM
    TonyM
    TonyM
    May 15, 2017
    189
    111
    Gender:
    Male
    Occupation:
    Retired
  5. Aug 30, 2018 #25
    J Harp
    J Harp
    J Harp
    Oct 7, 2008
    13
    1
    Looking closely at the splined shaft it appears the spline was first cut to depth with an end mill, then a wheel type cutter was run down the slots to form the profile.
    I'm wondering why you would put set screws on a splined coupling? Seems to me that would defeat the purpose of the splines.
    I'm no engineer, just a tinkerer, but my understanding is the reason for a splined connection is to provide a positive drive, while allowing a limited axial movement or some leeway in axial placement.
    Anatol likes this.
  6. Aug 30, 2018 #26
    BaronJ
    BaronJ
    BaronJ
    Grumpy Old Git.
    Dec 6, 2013
    728
    272
    Gender:
    Male
    Occupation:
    Retired.
    North Yorkshire
    Hi Anatol,
    Thank you for the complement.
    Just for the record:
    Is exactly how I would do it.
  7. Aug 30, 2018 #27
    Anatol
    Anatol
    Anatol
    Jan 22, 2018
    249
    39
    Gender:
    Male
    Los Angeles
    Thankyou! A name for it. Makes sense, this is a high torque low rpm application. But I think, strictly speaking, a splined shaft is a not a gear, for obvious reasons - one part - the coupling - doe not rotate around the other.
  8. Aug 31, 2018 #28
    nel2lar
    nel2lar
    nel2lar
    Jan 30, 2011
    195
    40
    Gender:
    Male
    Occupation:
    Retired Printing
    North Central Florida, USA
    I read that article from WILDHABER-NOVIKOV GEARS APPLICABLE. It make a lot of sense in his theory but I wonder why his was not kept because of load and stress. Somethings we just do not understand.
    Nelson
  9. Sep 8, 2018 #29
    nel2lar
    nel2lar
    nel2lar
    Jan 30, 2011
    195
    40
    Gender:
    Male
    Occupation:
    Retired Printing
    Anatol
    I think the document was written in Europe and the lingo is differ than ours. I remember reading the word pinion and that is something in clocks.
    Root bending stresses of pinion and gear with different loading positions have been analyzed. Effects on root stresses due to variations of fillet radius and normal pressure angle of pinion have also been investigated.
    I believe it was a good coupler for its application. It is different for sure.
    Nelson
  10. Sep 11, 2018 #30
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,267
    258
    It is pretty common in mechanical drives to refer to the small gear as the pinion. Thus the term rack and pinion where the rack has an infinite diameter.
    justintime likes this.
  11. Oct 11, 2018 #31
    john_reese
    john_reese
    john_reese
    Sep 10, 2016
    109
    17
    Anatol,
    I think your method of drilling holes on the pcd and boring out he center is workable. Ig you make he female spline long enough you can eliminate the need for hardening. Most tractor PTO shafts and couplings I worked with were unhardened.
    RM-MN likes this.
  12. Oct 13, 2018 #32
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,034
    460
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    Forgot to mention that I was in Edinburgh a fortnight ago. Nice example of the fluting in Rosslyn Chapel next to the Apprentice's Pillar. That has the mystical helix carved in it.
    N
  13. Oct 14, 2018 #33
    BWMSBLDR1
    BWMSBLDR1
    BWMSBLDR1
    Nov 17, 2017
    5
    0
    I have seen something very similar on a 1920's Miller 8 race car engine. nuts were circular with 4 semicircular cuts on the periphery. The socket was a cylindrical hole with 4 hard pins set into the body projecting halfway into the hole. Why it was don this way I do not know! Bill in Boulder CO USA
  14. Oct 14, 2018 #34
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,034
    460
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    The earliest gears were wooden wheels -with round wooden pegs to intermesh with others.
    Once the average tutor struggles to get students to understand Archimedes, everyone has lost interest .
    Once of the best bits of machinery was the Gutenberg printing press and made with wooden pegs as gears- some like what the topic started out as
    Ah well?
    Norm
Share This Page
