Were to buy 3 - 3.2mm shaft end mills in the UK
GrahamUK
Can anyone help me source End Mills with a 3 - 3.2mm shaft in the UK?
I have one of they cheap 3020 cnc router/mills, and was only supplied with a single endmill. Although it has done me well for making various aluminium stands and bases from wood laminate, alas it has gone dull :(
Tried using the dremel end mill to finish off a wood combination lock that I was working on, that was a disaster, only got halfway around a base in wood at 25mm/min before it ended up in 3 parts, so that got returned to the supplier.
Its a good thing we have the 'fit for use' laws here, i told the guy behind the counter what i wanted to do with the tool and he said it would work - hence no problem returning the broken one.
try these guys several folks here have purchased from them and been happy. I should get an order out myself.
3 mm mills are about $0.90 USD for HSS and $1.20 for carbide so you can afford to buy a dozen or two they have 2 flute 4 flute and they have ball nose so knock your socks off.
http://richontools.com
http://richontools.com/index.php?main_page=index&cPath=15_51
These are out of Hong Kong but they do ship direct to the UK and USA.
Hope this helps
Tin
3 mm mills are about $0.90 USD for HSS and $1.20 for carbide so you can afford to buy a dozen or two they have 2 flute 4 flute and they have call nose so knock your socks off.
Hope this helps
Tin
Hi Tin Falcon
Were you ever in purchasing.You are fantastic. Looks like I can forget wasting my time regrinding endmills. Use the new ones for steel.Recycle them for Aluminium.
Just went in to buy 10 pcs 12 mm 10 pcs 10 mm. I have been robbed by other vendors and paying too much for DHL etc. Bought a solid carbide endmill too. But do they stand up better than HSS..Thanks.
Thanks for the sourcing info.
Gus( had a good day fishing,fair weather,no rain and fish bite.Gus Grand Champ today )
Graham is looking for 3mmto 3.2mm SHANK not 3mm cutting endmills and I don't think Richon do any shanks smaller that 1/4 or 6mm.
In teh UK you could go to J&L/MSC they have a few metric and inperial size ones all with 1/8" shanks (3.175mm) and 3mm shanksbut they are not cheap, use the virtual catalogue an look at page 262, 279, 282& 284
http://www.mscdirect.co.uk/cgi/insrhm
Also take a look at Nicks MAN diesel thread he mentions the ones that he uses in his CNC machine somewhere.
JasonB is correct it is the shank diameter of 3-3.2mm i was looking for, so i will check out they links, but if anyone knows where i could get a 1/4" or 6mm collet that fits the 3020 standard spindle, i could cope with the shipping costs if im paying under $2 for an endmill.
The router/mill was a christmas pressie from SWMBO, so i dont know much about it yet. Im much more familiar with my lathe and its associated tooling. So all answers are appreciated.
OK looked at the sight again : closer this time
the HSS 3 mm em are 6mm shank sorry missed that. the carbides are 3 mm
shank so you are good to go there.
You can get ten end mills that for your machine for $ 12.00 us + S & H
sorry for the confusion.
tin
The Richon cutters are OK for general use, I've been using them for several years but in the smaller sizes on a CNC machine I would stick to something a bit better.
If its mostly wood then the FC-3 disposable type cutters are quite good and I would suggest you use two or three flute cutters rather than endmills which tend to have 4 or more flutes as they will not clear the waste as well.
Though having said that if you can get a 1/4 collet then look at the spiral router cutters as they have a cutter geometry that is mor esuited to wood.
J
I buy all my endmills / slot drills from http://www.cutweltools.co.uk/ they are good quality and often posted same day as ordered.
They have a huge selection and give a discount on your first order.
I recommend them highly.
The link in the above post shows the ER11, i have found the collet nut has printing on the bottom saying ER11A. Does the A make a difference? I tried googling for '3020 collets' and could not find anything relevant, would you mind telling me what you googled?
I think getting a 6mm and 1/4" collet would make sourcing bits much easier.
I will look into the various bits listed for the various materials, thanks. I have many plans for my machines, so i will be cutting allsorts on it. The lathe is so much easier, i invested in a full set of glanze indexable tools, and a nice selection of tips for various metals.
Best way to consume more of them. The other way round is much better. First aluminium, then steel.
Nick
I searched for 3020 CNC collet and got this, gives ER11 as collet
1
http://www.ebay.com/itm/4-Axis-CNC-...MILLING-MACHINE-With-Claw-Chuck-/390390623824
Agree with nick brass and aluminium first then steel, same with saw blades and files
Whats the matter with good old ebay,did a quick search for "end mills 3mm shank" seems a good few on there
Don
End Mills arrived today, got 5 from ebay, been to the stockholders and picked up some brass and aluminium, and ordered a set of collets for the spindle and some screws. Once the collets arrive, i will be moving up to 6mm shanks, as they are much more readily available for a good price. All in all its looking like its going to be a good week :)
I am going to start building the Vacuum engine from the downloads section - the one in german.
Thanks for the info on the mills, i appreciate it.
I have a lot of small carbide cutters with either 3mm or 1/8" shanks, 2 and 4 flute. They are readily available here in Australia, you might be best to try a supplier that specialises in to the engineering trades. Mine came from Carbitool in Melbourne.
Paul.
Hope this helps
Tin
Hi Tin Falcon,
I have no idea they deliver this fast.Maybe Hongkong nearby Singapore with just 4 hours flight. Placed order 7th Jan late evening.8th confirmed shipment made.9th Jan 9 am Emory or EMS came knocking on my door with the endmills. See my good buy.Looks like I have a life's time supply of mills. Plan to buy some 2mm 3mm 4mm sizes too later.
Mills came in same packing as mills I bought last year locally for a bit more$$.
Hi Abby,
Thanks for the info.
Just asked for quotes on spotting cum chamfer mills.. Sad to say my drilling is haphazard.
Centre popping not good. But I am improving.
