rangerssteamtoys said:
Ok this is the pump I plan to buy
http://cgi.ebay.com/Live-Steam-Engi...Z2594QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Pre-machined and everything. I just need a bit of help with the math. CORRECT ME IF WRONG.
Can anyone confirm this
The pump has 3/8" stroke and 3/4" bore
The circumfrence of the 3/8" rod is 1.278097245, multiply (divide) that by the 3/4" stroke and get 1.5700796327 So that makes it 1.57 cubic inches of water in every stroke of the pump, multiply that by the average RPM of the engine 1000X1.57= 1570 cubic inches per minute. Divide by 231 (amount of cubc inches in a US liquid gallon)
1570/231=6.79 gallons per minute.
PLEASE CORRRECT ME. This equation sounds way off so I need help, I'm thinking it should be around one gallon per minute.
Hi Ranger...... I have been watching this thread for some time now and I must congratulate you on your enthusiasm, it is great to see someone of your tender years getting stuck in to engineering, however, I regret to say your calculations are not quite correct.
The swept volume of the proposed water pump is considerably less than you have calculated...... you should take the CROSS sectional area of the ram and multiply by the stroke....not the circumference x stroke.
So: -
Area of 3/8" dia = 0.11045sq in x 0.75" stroke = 0.0828 cu in x 1000 strokes per minute = 82.8cu in per minute.
Divide by 231 (for US Gallons) = 0.358 galls per minute.
This would be the maximum volume of water pumped, however, you will probably not actually require this amount to all go through the coil and you will therefore need to install a water feed bypass system to return the unwanted amount to the feedwater tank....or, as Kevin has suggested, you can vary the pump rate.
To help you calculate the amount of water you actually need to put through the coil you must first calculate the amount of steam your engine actually requires in 1minute. and then divide this by the volume of steam produced by 1cu ins of water at the desired working pressure.
This will give you the number of cu in water your boiler must convert to steam per minute in order to satisfy your engines requirements.
At 150 psi, (still not really sure why you feel you need this high a pressure), 1cu ins of water will produce 169 cu in steam.
If you try and pump more water through the coil then all you will do is fail to evaporate it all and fill your engine with very hot water.
Conversly...if you pump to little you will end up with SUPERHEATED STEAM at the same pressure.
Monotube boilers (more correctly, steam generators) are not very user friendly when it comes to variable loading.
Controlling the steam output with a variable speed load, such as a steam engine, requires the use of: -
Either a variable firing rate....
Or a variable water flow....
Or a combination of both.
None of which are straight forward.
I hope this helps a little.
Best regards.
SandyC
;D
