Wall Water Witch
Virginia
This engine is an Elmer Wall design from about 1946. It has a 1 inch bore and uses spark ignition with a 3 volt model airplane coil. It has an aluminum piston with two cast iron piston rings. The fuel is gasoline or Coleman lamp fuel.
