Wall four cylinder running
rodue
Project of the Month Winner!
I bought the WALL, casting for this engine off E-Bay and machine them.
Wall is a high speed engine, with ball bearings on the crank and a
oil [ame]https://www.youtube.com/watch?v=iE9zCHeQDDw[/ame]
watch
pump. There are two videos.
[ame]https://www.youtube.com/watch?v=Dg5jgeGPWDY[/ame]
watch
Great job on the engine. It sounds like it runs very smoothly. What is the ignition timing?
gbritnell
gbritnell
It does run well I had a little problem with the float in the carb. because of its size you can't coat it with a sealer because it adds weight. the timing is around 6 to 8 degrees BTDC, Thanks for the interest.
