Hi Guys,
There are usually two places in a HDD that have precision bearings fitted. One of them is the head spindle. They are usually a dual bearing pack and often will just drop out with the application of a little heat, some are retained with a tiny screw, remove the screw and they will push out easily.
The platter spindle bearings are much harder to recover ! They are usually super glued or epoxy used to secure them in place. Not only that but often both bearings are pressed in from one end, sometimes with a spacer making it extremely difficult to get them out without damage. I've recovered quite a few of the much older 5.25" spindle bearings without a lot of trouble.
But techniques and methods of fixing has changed over time with adhesives becoming used much more. You also need lots of heat to destroy the epoxy used to secure the bearings which also boils out any lubrication that was in them.
As far as data on the platter is concerned, the minute that you handle them its been damaged beyond anything but forensic recovery.
