A few months ago I think someone asked about the correction charts for the Vertex HV6 rotary tables when working with the dividing disks because as supplied with the RT when new, they were wrong.
It is only now that I have found out the updated ones were wrong as well.
The set I have attached here is now guaranteed to be correct.
These should also work with other makes of copied RT's as well as long as they use the same dividing wheels and gear ratio of 90 to 1, plus they should also work with the BS0 dividing head. I will have to check the two I have to see if that is correct for the dividing heads, but can't be done yet as they are in outside storage and not in my shop at this time.
I will be glad when I get the two dividing heads converted over to Divisionmaster, it will save all the working out and handle spinning.
Sorry about that
View attachment HV6_Corrected.pdf
Sorry about that
