Up in smoke....
Help Support HMEM:
Scrat
Building a 5" gauge battery-electric loco.
Six huge axle-hung motors.
Yesterday I wired the controller, checked if both bogies went the same way and had her roll a few cms up and down the bench.
As the car batteries are quite heacy and had to go in and out several times during the process I used small 7 Ah lead-acid batteries.
The car battery clamps would not fit these so I used alligator clips to connect them.
Running to and fro without load was no problem but then I had the bright idea of checking how much power the loco had.
I leaned against the buffer beam and let her go forward.
*Flash of light*
*lots of smoke*
*electric smell*
The stall current of each motor is higher than 50 Amps.
Six motors vs flimsy alligator clips.
A few patches of melted insulation inside the loco, nothing left of the wires.
Clips were still in place.
Will test with proper batteries this week.
TonyM
North Bohemia Czech Republic
Sounds like you didn't have fuses in the circuit and the wires acted as a fuse. Batteries can deliver many times more amps than their AH rating.
Scrat
Hi Tony,
I have fuses but those are rated at several amps to suit controller and motors. A simple alligator clip will glow at about 1.5 Amps.
This was just a test setup.
