Uni-flow electricity making steam engine
Help Support HMEM:
bedgen
Hi to all!
I'm planing to make steam engine to get electricity in outdoor
what kind of engine will be best? (I'm planning to make uni-flow engine)
what more relevant for this? shaft torque or high rev/min?
what kind of valve is better?
and i want to make it in most simplest way
tnx for any advices
and any links for h.p. and boiler calculations?
steamer
Hang on a minute son.
Welcome to HMEM! We're a good bunch of people who build model engines and a variety of other things. We're a big group, and as such we like to know who we're dealing with and welcoming into our home. That's a reasonable expectation I think anyone would understand, wouldn't you? :)
If you could please, Please put a welcome post in the welcome section and tell us about yourself, where are you from, what do you want to build, what do you have for a shop ect.
and Welcome to HMEM! ;D
Rocket Man
According to the law if your boiler is smaller than 5 cubic feet or 5 gallons I don't remember which you are not required to have the boiler inspected.
The best boiler has the fire box in the center of the water jacket there is less heat lost. Do the math to calculate the outside diameter, fire box size, number of boiler tubes to make it legal.
The fire box needs to be no smaller than a 12" diameter pipe about 18 to 20" long. Put that inside of a larger pipe maybe 24" diameter. Weld on both ends then put in enough tubes to get the size slightly below 5 so it is legal.
steamer
Rocketman,
Considering he's from the Ukraine, I would just bet the laws are different.
Hell here they vary wildly by state.....
bedgen
Rocket Man,
Tnx! but im looking for math fomulas to fit heating square to make the engine work in nominal power( dependence between preasure revs/min diameter of piston and stroke)
seagar
Steamer.Do you have to be so rude to a newby who may not understand the protocol of this forum?This attitude noes not promote good will & friendship. :rant:
Ian.
jonesie
i do not think steamer was rude i seen the word" please"'used twice in his post.jonesie
bedgen
it was ok, and understandable :)
but guys, i still need advices
tattoomike68
HMEM Supporter
Im not sure how muck power you want to make. A machinist friend wanted the price on 15 HP steam engine to make power. the plans were $150, buy one done for under $2,000 it looked like a motorcycle v twin and not hard to make.
The big kicker was the boiler, it was $10,000+
It all depends on how much power you want.
Tin Falcon
Bedgen:
Steam is old technology as such there are Manny many books out there on steam engines and there design.
there is lots of stuff on http://www.archive.org/index.php type in "steam engine design " in the search block.
And as an engineering student get yourself a copy of machinery handbook.
The KN Harris books introductions talk a lot about sizing boilers to engines and scaling. it is directed to model engineers but a good start.
Rocketman brings up an interesting point . Check local boiler codes this could help you size your boiler without getting into a lot of red tape or government inspection requirements. there are many considerations to a design.
steamer
Bedgen,
For what your doing, how much power do you want to generate?
A flashlight or a city block?
1 kw or 100000 kw?
Start there and we can talk...hope you have deep pockets ($$$$) ;D
This steam hobby is never cheap...I can tell you that.
Tin Falcon
1 HP =33,000 ft/lbs/min = 746 watts or 746 joules/sec
IIRC the formula is P.L.A.N.
33,000
P is pressure in PSI at the piston
L the length of stoke in feet
A area of the piston in square feet
N number of strokes per minute
Going by memory here so if someone has the book in front of you feel free to elaborate.
tin
steamer
YUP...Thats right Tin
but thats brake horsepower. Thats the power at the engine shaft
There will be losses in the generator too.
You might get 5% efficiency from a steam plant in the 10000 watts range.
With that said, if you get 80% at the generator....and I think I'm being VERY optimistic,
10000/.8 =12500 watts in to the generator to get 10000 watts output
12500/.05 = 250000 watts of fuel into the boiler to get 10000 watts return....round numbers.
I hope you have one of those endlessly producing oil fields handy.... ;D
steamer
As far as heating surface. There are some general rules that work.
For a watertube boiler, you need 5 square feet of heating surface for every 1 indicated horsepower
For a firetube boiler, you need 10 square feet of heating surface for every 1 indicated horsepower.
Tin Falcon
the area where i live boilers need to have less than 10 square feet of area and less than 10 kw/hr of heat input bigger than that it has to be registered inspected etc.
tin
steamer
In Massachusetts, its over 100 pounds of steam per hour produced....
I have no idea what is required in the Ukraine Bedgen....you will have to figure that one out for yourself.
dwentz
In Illinois the limit is 1.5 square fee, and the inside diameter may not exceed a foot!
Dale
bedgen
I dont think that Ukraine have laws like that:)
but still, my engine will be little one
its like 0,2hp
Dan Rowe
Dale,
There is a thread for US State Boiler Codes. I just updated the list for Illinois.
http://www.homemodelenginemachinist.com/index.php?topic=8846.0
The exact wording of the exemption for Illinois is:
Sec. 5 (430ILCS 75/5) Exemptions
(7) Steam boilers of a miniature model locomotive, boat, tractor, or stationary engine constructed and maintained as a hobby and not for commercial use, that have an inside diameter not exceeding 12 inches and a grate area not exceeding 1 1/2 square feet, provided they are constantly attended while in operation and are equipped with a water level indicator, pressure gauge, and a safety valve of adequate capacity.
Dan
2
Group Builder
