Twin Cylinder Build
I have done a little more on this engine. Got rid of the round pillars and went for square. It still looks a little odd in the photo but in real life it doesn't look too bad and it is very rigid.
I have also turned up some hydraulic tube for the cylinders and a 1mm groove on their tops for a 33mm id viton o ring to be used as a gasket.
Hi all.
Cleaned it all up a little with some bead blasting and have made a couple of two piece con rods.Now i'm out to
the garage to make some two piece pistons .
