Turning a Hardend Ball Screw
Discussion in 'CNC Machines and Conversions' started by WAE, Feb 20, 2010.
  1. Feb 20, 2010 #1
    WAE
    WAE
    WAE
    Feb 7, 2010
    8
    0
    What is the best way to turn a ball screw in the mini lathe? I have to turn one down for my Fignoggle CNC conversion I am doing for my mini mill, and it is chipping and dulling my carbide tips pretty quickly :-[
    Thanks!
  2. Feb 23, 2010 #2
    toolsrul
    toolsrul
    toolsrul
    Active Member
    May 5, 2009
    31
    1
    What is normally done is the ends are annealed (softened) then machined then heat treated. If that's not an option try a negative insert with a tough grade of carbide like a Kennametal KC850 & run @ 50 sfm dry. If your finish changes from shiny to dull your part is case hardened & you broke thru the case.
    Rigidity is the key - spindle, holder, ways, feed screw, etc. Good luck.
  3. Feb 23, 2010 #3
    spuddevans
    spuddevans
    spuddevans
    Feb 25, 2008
    204
    1
    The other option is if you have ( or have access to ) a tool post grinder you can grind the ends to size. I imagine this would be a lot easier on the mini-lathe, but would most likely take longer than regular turning.
    Depending how hard the ballscrew is it may be the only option if carbide isnt cutting it.
    Tim
  4. Feb 23, 2010 #4
    WAE
    WAE
    WAE
    Feb 7, 2010
    8
    0
    Haven't been able to check this site after I first posted, but this is how I ended up completing it. I don't know if it was right or wrong - and I hope i didn't warp anything - but first I ground the threads off with my bench grinder, then took a propane torch and heated it until it turned red, then plunged it into a bucket of cement mix (it was sitting in a bucket from where the bag broke) and let it cool for an hour. Chucked it back into the lathe and it turned very easily!
Draft saved Draft deleted
Share This Page
Group Builder
