Hi to everyone ,
Can some one please tell me the best way of tuning the motors and setting the XYZ axis on a converted SIEG X1 (direct motor coupling). I am going to be using MACH3 and I wish to keep the motor speed and acceleration quite modest until I get to know the whole systems real world capability. I was hoping to keep the the XY motor at 50mm per minute and the Z axis at 25mm with the acceleration at about 1/3 of the speed. Does this make sense if I kept the micro stepping at 1/2, ie: 400 steps per revolution, the motors are the usual 200 steps affair, the lead screws for the XY are 2mm in pitch and 1.5mm for the Z axis. I would also wish to fine tune the XYZ travel by physically measuring the real travel against indicated and let the MACH3 correct the steps to correct the travel.
Thanks for all your help in advance.
Best Regards,
A.G
Best Regards,
A.G
